Old 11-10-2010, 03:29 PM
SuperJetski45 SuperJetski45 is offline
Designed for CF Vacuum Bagging
I got alot of reading to do and catch up on some of the knowledge departed here. From other forums, I'll try to seach for the answer first....
I've been working on prototypes for a new design in Jetski's, they were produced for a Science Channel Show called MACHINES! S01E04. It was a sort of crotch-rocket on the water.
The second generation of prototyping is underway. After the CNC machine cuts my PPE foam, we are going do a vacuum bagging process of the CF.
Has anyone used Strectchlon 200? It seems more appropriate than Vinyl if there are many contours...
Old 11-10-2010, 09:55 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...i have not used Strectchlon 200, but if it contours better than anything else in your local area, go for it. Smooth contours make far better results in the end result, so even if it is a bit dearer, it may be well worth the money. Carbon Fibre is expensive, the end results are imperative to get it right first time....
What is vacuum bagging? RTaylor Boatbuilding 6 04-06-2008 01:14 PM
Vacuum bagging and Vinylester fede Fiberglass and Composite Boat Building 10 12-19-2006 03:32 AM
Recommended vacuum pumps for vacuum bagging? James Mills Materials 1 12-17-2006 03:11 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 03:25 PM
Vacuum bagging bulkheads tbot Fiberglass and Composite Boat Building 4 03-11-2005 07:00 AM
