Design Thoughts
Discussion in 'Boat Design' started by benha, Sep 21, 2016.
  1. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    I/Os and outboards are dangerous for divers. Inboards are the usual setup.
  2. Mr Efficiency
    Mr Efficiency Senior Member
    Outboards rule these days.
  3. Mr Efficiency
    Typical abalone divers rig, cat around 7.5m
  4. philSweet
    Likes: 461, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
  5. benha
    benha Junior Member
    Clearly an I/O would be great for layout, but I'm not a fan. Not only does it have "boat sinking" implications in that you're relying on an articulating bellows seal to keep water out of your boat, but it's also the only configuration that involves running the power train itself through a knuckle. If I were to build an inboard I'd use a v-drive transmission to push the engine rearward, but for me the only good options are "real" inboard or outboard...
    I've seen a couple of shamrocks around. Nice boats. Part of this is that I'm looking for a boat building project though. I could try to find one to pull lines and layout from one and mimick it, but that might prove challenging. Not a lot of those things around in these parts.
  6. Barry
    Likes: 509, Points: 113, Legacy Rep: 158
    Barry Senior Member
    I am pretty sure that even if the bellows cracks, water will not get into the boat. At least with Volvo
  7. PAR
    PAR Yacht Designer/Builder
    Agreed, if you're not willing to do reasonable maintenance, you can't blame the design. By this I simply mean there are countless tens of thousands of I/O drives still floating, some with leaking bellows and all. I see boats all the time with over 20 year old transom kits on them, when I do the replacement.
