  #31
Old 11-29-2008, 02:17 PM
CET CET is offline
Rep: 10 Posts: 114
Originally Posted by Loveofsea View Post
Here are a few things that make this hull work so well. The hull is flat all the way to the bow. The widest part of the hull is 2/3 forward, and 8" wider than the transom. i carry 54 gallons of fuel in the fwd 1/3 of the hull (in portable tanks that nest under the deck) I use a SST lifting strake across the transom with a cutout for the engine to create exagerated transom lift..
__in other words, most of the weigh is pushed max forward. The impact point of the hull is 2/3 fwd where the hull is the widest..
two opposing factors come into play here--the inherent bow lift from pushing a wider fwd hull over the water and the exagerated trasom lift from the SST lifting strake across the transom. The hull creates lift both fore and aft---that has the effecy of keeping the hull stuck to the surface. if it doesn't lift, it will not slap back down. The impact point (the widest point) uses the extra weight of the fuel along with the exagerated transom lift to crush the water and send it out the sides.
Here is a link to a stroy that was done about the 'Good Skiff' last year...
http://www.oceanskiffjournal.com/
Interesting ideas. A 19' flat-bottom dory ought to run quite well with a 25 - 40 hp motor. I have a hunch yours requires a good deal more than that.
  #32
Old 11-29-2008, 06:08 PM
ancient kayaker ancient kayaker is online now
aka Terry Haines
Rep: 1811 Posts: 3,007
Originally Posted by TeddyDiver View Post
... but also for ugly gents talking dirty ...
That explains the many, large shaded volumes, clearly for beer storage.
Dances with Turkeys
  #33
Old 11-29-2008, 08:59 PM
messman messman is offline
Rep: 19 Posts: 29
LOL..I think that was to be a secret, so the Better Half dont find out. Hope she dont read the forums.
Teddy,
I cant wait to see it completed and to hear your review of it once you splash it.
Chris
  #34
Old 11-29-2008, 11:27 PM
aka Terry Haines
Me too.
p.s., I can keep a secret. Tell me more of them.
Dances with Turkeys
Some suggestions needed, 1 person mini speed boat design residentgearhed Boat Design 14 06-19-2011 03:05 PM
Bass Boat design, my first, will it work? suggestions... garrick Boat Design 17 03-30-2008 05:23 PM
Small O/B v-hull....design suggestions? pbplayer78 Powerboats 0 12-10-2007 08:52 PM
Bass boat design (any suggestions/info) justinDesign Boat Design 0 10-19-2006 12:22 AM
Suggestions for submitting boat design plans to industry/partners Marcum Marine Services & Employment 1 08-07-2001 11:55 PM
