Old 04-03-2008, 06:22 PM
fishy1 fishy1 is offline
Rep: 10 Posts: 25
A design for a rowing fishing boat?
I'm looking to build a boat for longlining from. It must also be suitable for lifting nets and creels. It must be stable, even in bad weather. It should be good to row, as it will have no engine. (Fishing regulations). I'd probably just have one crew on it, plus fishing gear, although the option for two or even three rowers would be good.
I was thinking something 12-16ft long, don't really know what else. Stitch and glue would be it's construction ideally. If anyone knows of a suitable free design, please let me know. I don't have a huge amount of money to throw at this, so the cheaper the better. (Although obviously it still has to be safe.)
Thanks alot.
Old 04-04-2008, 11:07 PM
kengrome kengrome is offline
Rep: 287 Posts: 719
Here's a good place to start:
http://www.duckworksbbs.com/plans.htm
From Steven Lewis, one of the designers:
Duckskiff is a 14 foot skiff I designed for a buddy of mine named Tim that I work with. Tim is an avid Duck hunter and wanted a fairly lightweight boat but in nice quiet wood rather than noisy aluminum. He also wanted something a little boatier than a Johnboat styled craft. What I came up with for him is a 14 ft long 5 ft wide at the shear (45 inches wide at the bottom) kind of semi-dory hull. I did this to make it an easier and dryer proposition when pulling a large dog over the side and back into the boat. The additional ultimate stability of the 23° flare to the sides allows a lot of weight to be right at the sides of the boat while at the same time getting the shear lower to the water. He wanted to be able to use his 7 hp motor to get around now with the probability of upgrading to a higher hp later on. As the hull was originally derived from a rowing style hull I was playing with a few months previously I tweaked both of them so that they were brother and sister similar and decided to present them to you here. Enjoy…
Free plans are here:
http://www.duckworksbbs.com/plans/le...kiff/index.htm
Kenneth Grome
Old 04-05-2008, 12:55 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Scandinavian type lapstrake is one possibility. Google pictures "soutuvene" (rowboat in finnish) and you see variety of boats..
They can be made of plywood aswell when it's hard to find proper timber..
Old 04-05-2008, 04:58 AM
Rep: 472 Posts: 615
Doris boats of East Coast of the States and Newfoundland -Terreneuve Canadian doris are perfectly matched to the use you want from your boat. Doris are easy to build from plywood end epoxy resin (I do not recommend the variants made of plywood and poyester resin, as it is not a durable or safe combination) and fairly cheap when home made.
Use a good plywood, like a marine lauan, or meranti or finnish or russian pine plywood. Do not use an expensive okoume, it's not worth the price in your use. Use white light pine or epicea for the stringers and other pieces of "solid" wood.
You'll find in UK good epox resin, and cover all surfaces with a 165 gr/sq meter fiberglass with at least 3 coats of resin. Finish with 3 coats of an acrylic paint car. I made a 17 feet doris in 1981 for rowing, fishing and I put later a 9.9 HP Honda outboard. I sold it in 1994 and the boat is still in use...
You´ll find a big bunch of plans at Wooden Boat magazine and in the internet. Buy a plan very detailed with complete list of materials and a building manual even if it's a bit more expensive. Take at least 16 feet for 2 crew and 18 feet for three, but do not go over 19-20 feet as it becomes too heavy.
The Doris chine hulls with composite seams are the easiest to make as it does require very little skills in carpentry. Forget lapstrake it's too long and unsuitable for a beginner. See for the possibilty to make the boat unsinkable with foam.
http://letolet.ifrance.com/letolet/doris/plans.htm look Doris Portugais 5m17 for the pictures and the plans.
http://www.shoestringshipyard.com/woodsholedory.htm interesting.
http://www.woodenboat.com/forum/show....php?p=1806824 that may give you some ideas.
http://www.woodenboat.com/ wooden boat magazine
If you need more infos send me a message. Cheers.
Old 04-05-2008, 06:21 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Fishy1,
Some small boats at http://www.bateau.com/categories.php?cat=28
http://www.epoxy-resins.co.uk/
Good luck,
Pericles
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 04-05-2008, 07:58 PM
Rep: 10 Posts: 25
What about either the smaller or larger version of this?
http://www.gsahv.pp.fi/ecodory/ecodory.htm
Also, so I can get an idea of how much epoxy would be needed to cover it, how much area does 1l of epoxy typically cover on ply? What about with fibreglass, how much then?
Thank you all.
Old 04-06-2008, 02:26 AM
Pericles's Avatar
Measure from the centre to the gunnels at intervals along the hull to get an average figure and multiply that figure by the length of the hull. You now have th area of one side of the craft. Assuming you will laminate glasscloth both inside & out, multiply by 4. For resin usage, that's personal to the way you work.
There are free plans at http://www.epoxy-resins.co.uk/plans/freeplans.html & the quantities for resins are included. Having just looked at the dory plans you linked to, a three sheet boat requires 8' x 4' x 3 x 2 = 192 sq. feet or 17.86, say 18 sq. metres.
Explore & extrapolate. http://www.epoxy-resins.co.uk/plans/freeplans.html
15' 9" Overall length by 5' 2" Beam Dory Skiff " Morgan"
Morgan
The Kit Contains the following:
15 kg of Epoxy resin/hardener
2 kg high density filleting mix
5 x 1" laminating brushes
5 x 2" laminating brushes
10 Mixing Pots
25 Mixing Sticks
5 pairs Latex gloves
Calibrated measuring pumps for resin and hardener.
2 Squeegees bevelled edge
10 Short pile rollers
1 Roller frame
1 Roller tray
2 rolls 50 mm x 50 metre fibreglass tape.
2 rolls 75 mm x 50 metre fibreglass tape.
2 x 5 metre fibreglass cloth ( Sheathing )
2 x 1 litre cleaning solvent.
Drawings: 2 A1 pages of ready lofted highly detailed Drawings including drawings of 9' dory oars.
U K Epoxy resins manual Morgan
Check out the project gallery
and watch "Morgan" being built
just click the image.
To buy a similar version of this boat in a pre cut kit form will cost you over £2100 to build. Our Resin/Drawing Kit is just £341.25 !!
BTW, it's good practice to remove the screws and nails as their presence will cause rust to form or damage your tools at some time. Looks at the snow outside this morning, building a sled might be fun.
Pericles
Old 04-06-2008, 11:19 AM
Rep: 10 Posts: 25
I can manage to work out the area of ply to be covered easily enough, it's just a rough figure of how much epoxy per coat would be needed per m2 would help my calculations greatly. I'm thinking of probably hannu's big sister design, but not 100% yet. If I did do it, I think I'd use ply on the bottom instead of his floorboards.
BTW, what is the reason dories taper towards the transom? I am sure there must be a reason, whether it is stability or rowing or something, but surely leaving it wider would allow a much bigger space, with not much more weight?
Old 04-06-2008, 11:31 AM
Pericles's Avatar
Fishy1,
You have asked a much bigger question than you thought. For the answer your must do your own research, for to travel in expectation is better than to arrive. You have to understand it is the journey of learning that makes us better people, Grasshopper!
The journey starts here.
http://en.wikipedia.org/wiki/Dory
Pericles
Old 04-06-2008, 07:27 PM
Rep: 287 Posts: 719
This is an interesting question, and when you ask in the context of this thread I have to wonder why you're considering a dory in the first place, especially when one of your first requirements is:
Dories are well known to have low initial stability until heavily loaded, whereas boats with wider bottoms feel much more stable without a load. It seems you might better be looking for a boat with a wider bottom, especially given the 12-16 foot length you prefer.
A dory in this size will be rather limited in terms of what you can carry anyways. It will most certainly be a one-person boat. Even a strictly one-person dory is usually longer than 16 feet. Here is one of the smallest I know ... and yes it is one of the boats in the link I posted for you earlier:
http://www.jwboatdesigns.co.nz/plans...dory/index.htm
By the way, that earlier link I posted includes the designers of dozens of good rowboats. Which of these designs are particularly interesting to you? Maybe if you choose one or two of them we can talk about the specifics so you can get a better idea of what you really need ...
Kenneth Grome
Old 04-06-2008, 07:54 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
The United Nations Food and Agriculture Agency offers free plans for the exact need you want.
http://www.fao.org/docrep/007/y5649e/y5649e00.htm
Included are complete instructions and materials requirements.
Tom Lathrop
Old 04-07-2008, 07:10 PM
Rep: 10 Posts: 25
I would be certainly loading it heavily most of the time, with nets and other gear, and also fish. I accept that the 16' might be too small for a dory, I'd be willing to go bigger. The design of the boat does not really matter to me at all as long as it's stable, good to row, and can carry lots. It's looking like I will probably have another guy with me on it all the time, so I accept it needs to be bigger.
The UN model was interesting, but extremely heavy.
Old 04-07-2008, 10:04 PM
Rep: 287 Posts: 719
Yes, now you're talking!
I think Big Sister is the one you want. I say this because Little Sister can take two people, but if you'll be carrying two regularly (plus a lot of gear) you'll no doubt be happier with more room inside, as well as more freeboard and greater carrying capacity. It's amazing how fast a working boat "runs out of room" once you start loading it with everything you want / need.
Big Sister will also be better able to handle 3 or 4 people, whereas I think Little Sister would be cramped with just three, even without the fishing gear.
The plans are the right price too ...
Kenneth Grome
Old 04-08-2008, 02:57 PM
Rep: 10 Posts: 25
Plus, it'd not got lots of shapes of wood to cut, just a few. Would there be any major differences if I changed the bottom to 3/4" ply rather than his floorboards? As in, would handling etc change? How fast could you get the big sister to go with only one rowing?
Looking for a classic Greek fishing boat design plans Larry Boat Design 16 06-18-2011 08:44 AM
Coastal Rowing Boat Design Oarsman Boat Design 4 09-09-2006 09:07 PM
New Fishing Boat Design grp.boat Boat Design 16 12-25-2005 10:20 AM
15' rowing boat design need HELP noonagon Boat Design 5 09-20-2005 06:41 AM
need drawing of rowing boat arch3d Boat Design 11 04-20-2004 06:43 AM
