Old 11-13-2011, 11:25 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
I think that's what a lot of us do, Basil.
I always work with the true dimensionless ratios for design, but all my spreadsheets that use them have a few lines to convert them to the traditional form, just in case someone wants to compare them.
Old 11-13-2011, 11:30 AM
BASIL J WALL BASIL J WALL is offline
designer
Rep: 10 Posts: 11
Thanks Matt...
I will now modify my spread sheets...
Basil
Old 11-13-2011, 12:24 PM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Thanks for the explanation Matt. In my design work, I use the S.I. system the modern method of the metric, to be on the mainstream. But in my work as a surveyor, I still encounter a lot of ships with the U.S. English system and our reporting requires us to report the fuel in the Imperial system because the country I work for has adopted the British system. You will also be surprised that the word ton is so frequently used without reference to M.T., S.T., or L.T. Makes me think the world has not changed after all.
Its nice to know there are other ways of expressing DLR ratio as the Principles of Naval Architecture stiil list the design lane in DLR ratio. Have to "modernize" my spreadsheet so I can work purely on dimensionless ratio.
Old 11-13-2011, 12:29 PM
Rep: 746 Posts: 785
Originally Posted by marshmat View Post
-S-number, which takes the old-style DLR as one of its inputs.
What does the S stands for. Or what does S/Sqrt(displ x L) stands for?
Old 11-13-2011, 12:52 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Essentially a performance rating number for monohull sailboats which can be calculated from generally available information. Eric Sponberg included it in his "The Design Ratios" article: http://www.sponbergyachtdesign.com/Articles.htm
David Cockey
Displacement hull design for lower horsepower (british seagull) ber1023 Boat Design 5 11-04-2011 11:44 AM
Design Ratios ancient kayaker Wiki 0 11-08-2010 10:43 AM
Identify this boat: A Weird Units challenge for Metric/Imperial debaters marshmat Open Discussion: All Things Boats & Boating 19 07-30-2009 12:52 PM
British standard bs 6349 part 4. Code of practice for design of fendering and mooring asotoe Open Discussion: All Things Boats & Boating 0 03-25-2009 05:39 PM
What metric scales used most commonly in yacht design Grant Nelson Boat Design 6 05-08-2008 03:06 PM
