  #31
Old 02-17-2017, 05:22 PM
UpOnStands UpOnStands is offline
Rep: 16 Posts: 285
Originally Posted by HJS View Post
This showed hull form is based on our long experience with rowboats for unprotected waters. Reducing the pitch was precisely one of the important requirements, in addition to getting the lowest possible drag at Fn 0.7 in this proposal it correspond to 15 knots.
interior height over keel in the cockpit is what? 1.26m? minus thickness of roof and floor etc.
so internal height available for engine is 40 cm? what type of engine?
Canoes work only if the paddler is active in controlling stability and of course are much slower.
Your flat keel, high bow, and fine sections suggest that the boat will be impossible to hold to a line in wind or cross waves.
For OP, which part of Skagerak? Seems as if you are looking at travel times of 6-10 hours depending on weather. Very few of us can sit in a constrained cocoon for that length of time -- for a race, maybe.
  #32
Old 02-17-2017, 05:47 PM
fallguy fallguy is offline
Rep: 10 Posts: 8
What about smaller Wood's Skoota? Some more cost in an extra hull(inside humor aside Richard), but lots of margin of safety. Richard might not like me suggesting it, but the instant I saw the picture of the boat crossing Juan de Fuca, I thought about his Skoota 20. If nothing else, well worth checking out if you like boats.
  #33
Old 02-20-2017, 03:41 AM
HJS HJS is offline
Member
Rep: 288 Posts: 249
so internal height available for engine is 40 cm?.
Internal height available for engine is 70 cm
Interior height in the cockpit is 150 cm
Calculate and test, no guesswork, please.
js
Design proposal - help needed-tri-12-m-jon-fu.jpg  Design proposal - help needed-tri-12-m-jon-fn.jpg
www.sassdesign.net
I'm not lost, I'm just uncertain of my position.
I'm still confused, but on a higher level
  #34
Old 02-21-2017, 03:08 AM
Jon E Jon E is offline
Rep: 22 Posts: 51
Originally Posted by Stumble View Post
So the only way I can see to keep the desirable speed and power requirements is to move to a multihull of some sort. As weird as it seems I really do thing a power Proa maybe the best solution. It eliminates the docking issue with a stabalized trimaran, doesn't require twin everything like a cat, and isn't terribly complicated to build. My only concern is I don't know how much it will attenuate rough weather.
Proa sounds very interesting, Stumble. I don't know how much it will attenuate rough weather either. Anyone having experience?
  #35
Old 02-21-2017, 03:15 AM
Rep: 22 Posts: 51
Loa 12,6 m
Boa 1,28 m
Lwl 12,0 m
Bwl 1,07 m
Displ 1,4 ton
15,0 knots 26 hp
10,0 knots 8 hp
Very interesting HJS. What about stabilicing your suggested hull with a proa? Easy construction in aluminium is important, so the shapes must not be too complicated.
  #36
Old 02-21-2017, 03:54 AM
Rep: 16 Posts: 285
my understanding is that proas are not great if the wind/wave direction is variable.
Constant tradewinds are its specialty.
  #37
Old 02-21-2017, 03:57 AM
Mr Efficiency Mr Efficiency is offline
Rep: 677 Posts: 5,372
Gawd, I wish those cooling trade winds had been blowing a bit more in the Australian summer.
  #38
Old 02-21-2017, 04:17 AM
Rep: 16 Posts: 285
bet the foam cored hulls got soft, real soft.
  #39
Old 02-22-2017, 01:53 AM
HJS HJS is offline
Member
Rep: 288 Posts: 249
Check email, private message
js
www.sassdesign.net
  #40
Old 02-23-2017, 12:40 AM
Stumble Stumble is offline
Rep: 739 Posts: 1,878
In an absolute sense I don't know, but a friend owns Jzzero, a pretty famous ~37' sailing Proa he soloed/duoed to New Orleans from Seattle. With an average speed from Panama to New Orleans of about 14kn. But this has a lot more liveaboard capability than you would need.
Greg Rubin
Captain-Attorney-Boat addict
  #41
Old 03-11-2017, 05:07 AM
peterAustralia peterAustralia is offline
Rep: 233 Posts: 339
My handle on the concept is this. A low power long thin displacement Hull.
A starting point may be the 21 feet long boat that Seiko namajira crossed the Atlantic with. Power was a, 2.5 hp tohatsu outboard. Beam was 5 feet and draft was 2 feet. Just scale up his boat by thirty percent or so. I think 15 knots is too high. I think 9 or 10 to be much more realistic
Just Google tohatsu outboard Atlantic Ocean crossing for the website
  #42
Old 03-11-2017, 07:58 AM
Turnpoint Turnpoint is offline
Rep: 10 Posts: 45
I would definately recomend a power catamaran or stabilized mono for this type of craft. You will need a very fine hull shape to meet your power requirements and if you go with a monohull you will create a vomit rocket unless you add some form of active stabilizing system such us stabilizer foils and or a gyro stabilizer system.
I would much rather have a boat like Richard Woods Skoota that you can walk around in, carry some people and overnight on if you needed.
I have made two boats that are applicable (im not trying to sell these designs but hope my experience is usefull). The first was a 24 foot trimaran with a 20 hp outboard and 20 knot cruise speed. The customer uses it often to cross the straight of juan de fuca which can have some terrible conditions for small boats ... open ocean swells stacked up by large currents and usually on the beam. Teh tri is safe in these conditions but can develope an uncormortable motion and wants to broach if surfing a big swell. It also leans outboard in the turns which feels really weird. We have since added hydrofoil assist and the speed is now up to 24 knots but the biggest gain is its stability... it now has a comfortable ride and stays flat in turns.
The second boat we made was a 24 foot cat with twin 20 hp outboards. This is my own boat that I use to get accross the Straight of Juan de fuca. The ride is a lot more comfortable and you can take more people and gear, take the kids inner tubing, knee boarding, sleep overnight, and walk around. The trimaran feels like a motorcycle and the catamaran feels like a comfortable mini van. On a long trip I would definately want to be on the catamaran. We also added foils to this one and top speed went from 20 to 24 knots... but the biggest improvements were in ride comfort in a seaway, and load carrying ability. Without the foils the boat would start to get bogged down with more than 3 people and now we can have 6 people onboard and still maintain 20 knots.
Hope some of that helps your search.
  #43
Old 03-11-2017, 12:57 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 1067 Posts: 1,975
An appropriate length for an efficient 1 ton craft would be about 24 feet or 7.3 meters. Additional length won't help in rough conditions. For cheap, you want an outboard motor. That also limits your options for hullform. The good news is that this was exactly the challenge faced by boat designers during the 50s and 60s when outboards were just coming into their own. Johnson introduced the V4 50hp outboard around '58. Look at the '60s commuter and utility designs for inspiration. There are a few modern interpretations.
http://yachtfocus.co.uk/new-boat/nie...marine-pts-26/
note, they seem to be listing the speed as 15km/h, not in kts, which is a bit cheeky, or a typo. And this one happens to be 2.5 tons. Keep the design, drop the amenities, maybe shave a couple inches off the beam, swap the diesel for an outboard, and I think you are getting close.
more eye candy
http://www.prinsvanoranje.nl/en/yach...sic_-_New.html
A modest proposal CDBarry Software 10 03-20-2014
04:13 AM
Dissertation Proposal abhiprayj Projects & Proposals 6 10-20-2011
11:23 AM
Project Proposal : proa design for handicapped sailors tspeer Boat Design 12 06-29-2008
12:44 PM
Proposal for catamaran rudders b_rodwell Multihulls 15 12-28-2007
10:50 PM
The Elipse - A Proposal venomousbird Projects & Proposals 23 10-15-2007
06:26 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
