Old 01-23-2007, 09:45 PM
Wayne Grabow Wayne Grabow is offline
Rep: 260 Posts: 151
Design parameters for Keel Pad
When looking at posted photos of the construction sequence for Ken Basset's runabout design, RASCAL, I noticed the keep pad design which is supposed to markedly improve planing performance. The keel pad appeared to me to resemble a large waterski integrated into the bottom of the boat. Since I am working on a design for which it wouldn't be too difficult to incorporate a similar design feature, I am wondering if I can get some advice on any critical parameters. How fast do you need to be going (19' hull) to make a keel pad worthwhile? I suppose that its area should be proportional to the supported weight and intended speed range. Looks like it is flat for most of its length with a bit of upward curve (like a waterski) at the front. Any guidance on what portion of the overall chine beam should be included in its width? Any major drawbacks at non-planing speeds? Any internet papers which discuss this feature in detail? All help will be appreciated.
Calculating hull weight from materials and design parameters JonathanCole Boat Design 18 01-13-2006 02:44 AM
pontoon boat parameters: basic sources? helipilot Boat Design 5 08-21-2005 10:29 AM
pad design project an constructions riveramunizaga Boat Design 2 07-19-2005 05:47 AM
propeller design parameters fcfc Props 2 09-16-2004 08:49 AM
Pad Design Boat Design 9 02-25-2003 04:14 PM
