Old 08-26-2009, 11:55 PM
issac82 issac82 is offline
Rep: 6 Posts: 31
Design Life
What is the design life of GRP boats.How can we estimate its design life?
Old 08-27-2009, 12:18 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Hello Issac82,
GRP lives forever. Someone else may tell you otherwise but in my experience it will outlive you. The GRP should be protected from sun (UV) though or else the resin will disintigrate over time. If it is protected in my opinion there is no limit.
Regards
Fanie
Water ! Just gimme water !
Old 08-27-2009, 12:30 PM
amateur mariner amateur mariner is offline
Rep: 30 Posts: 44
Still how to predict the design life??
Old 08-27-2009, 12:49 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,251
Like Fanie wrote, without UV protection by gelcoat or paint, the lifespan is short. I've seen repairs done 5 years ago where the glass is already above the surface. On the other hand there are well built boats from the 70's in good condition.
As a general rule, the parts that are installed/attached determine the lifespan of a boat. Stern drives in seawater: 15 years, in inland waterways 25 years. Stern drives without service: less than 5 years.
Another point is that long after the 1th owner has discarded his boat because it has lost its gloss, the 3rd or 4th owner may still be happy with it once the scratches have been repaired and the hull was painted over.
Old 08-27-2009, 06:58 PM
bntii's Avatar
bntii bntii is online now
Rep: 1073 Posts: 704
I am happily sailing about in one of the Bounty II series yawls- 53 years and going strong.
There is another exhaustive thread on this subject around here somewhere...
If I could summarize the thoughts in one sentence: If the material yields beyond a critical amount in each cycle, the design life will be limited to a finite number of cycles.
The engineers will no doubt weigh in ..
Old 08-27-2009, 08:21 PM
joz joz is offline
Rep: 10 Posts: 134
I read an article from Professional Boatbuilder to which they are starting to recycle old GRP boats that are 40 yrs old to which you place your old boat in this machine and it destroys the boat to which the fibreglass can be re used in the production of a new GRP boat (powder form), plus it seperates all items whilst it breaking the boat which is quite interesting.
Old 08-27-2009, 08:58 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Same simple answer as I gave in another thread... "Depends"
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 08-27-2009, 10:11 PM
ancient kayaker ancient kayaker is online now
aka Terry Haines
Rep: 1811 Posts: 3,007
Way back in my motorbike days it was common knowledge that the fiberglass helmets we used back then softened with use and had to be changed every couple of years. I don't know why, body heat, moisture, poor material, whatever ... I wonder if it was the resin used and if some boats hade the same problem.
Dances with Turkeys
Old 08-30-2009, 09:40 PM
Rep: 30 Posts: 44
Can somebody quote a reference about it?
Old 09-02-2009, 12:35 PM
Rep: 30 Posts: 44
Somebody quote some reference of the statements already mentioned.If there is any mathematical formula published mention it over here.Waiting for answers
Old 09-02-2009, 12:46 PM
Fanie's Avatar
Fanie
There is no formula, only estimates.
To make an estimate valid you have to supply all the conditions.
Regards
Fanie
Old 09-02-2009, 02:44 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 569
Joz do you have a link to that PB article I looked on their website and couldnt find it - I would be really interested to read it.
Thanks
Richard
Old 09-02-2009, 04:30 PM
joz joz is offline
Rep: 10 Posts: 134
RHP
I'll try to find that edition for you give me a week or so.
Old 09-02-2009, 06:06 PM
RHP's Avatar
RHP RHP is offline
Many thanks.
Old 09-02-2009, 06:18 PM
Amateur Mariner, there is almost certainly a great deal of information about the duty cycles / design life of GRP, though much of it would be proprietory. The problem is that there are so many variables that impact on the results of such testing that they are all but worthless to the bulk of the designing / building community. Get five people to laminate a given part and you will get laminates with 5 different sets of properties. Hell - get one person to laminate the same part 5 times and the same will be true!
Different resins, fibres, core materials, laminating procedures, temperatures, curing times and conditions, humidity, mixing times... the list goes on and on...
Will
www.imaginocean.net
Life Landlubber Open Discussion: All Things Boats & Boating 2 05-22-2009 06:41 PM
What design features make life aboard comfortable & practical for females? Wilma Ham Boat Design 456 07-31-2007 06:22 PM
battery life 3pepper Boat Design 2 01-20-2007 05:00 AM
Life Jackets mackid068 Open Discussion: All Things Boats & Boating 45 08-20-2006 08:54 PM
Life Jacket Design Competition brian eiland Projects & Proposals 2 05-23-2006 11:41 AM
