Old 12-17-2001, 01:30 PM
Design Books
I am working on a ship hull suvery/inspection software program. I am looking for any books that would be a good source for describing hull design. I'd like a book that had some good visuals of ships including information on all the outer hull numbering such as frame numbers and waterlines, etc.
I'd also be very thankful for any websites/companies that might be able to give me this kind of information.
Thank you in advance for your help.
Gregory Kaufman
Old 12-17-2001, 02:34 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
For yacht design, http://www.vacantisw.com/Books_On_YachtDesign.htm has an excellent book list. For ships, visit www.sname.org or search on the name Thomas Gillmer.
Old 12-17-2001, 04:13 PM
Frame spacing & numbering
Typical frame spacing on ships is 24" or 610mm, though it varies. 20" or 508mm is also common, as are spacings in between. Frame 0 (zero) is typically at or near the rudder post, and they are numbered from there forward. Negative numbers are typically used for frames aft of the rudder post. While this is the norm, there are lots of exceptions where the frames have been numbered in some other way.
Old 12-17-2001, 04:20 PM
Admin Admin is offline
www.boatdesign.net
Rep: 42 Posts: 40
--- begin shameless plug ---
I'll also mention our list of books, most of which are linked to Amazon (where you can see customer reviews and also buy used copies of some books.)
http://boatdesign.net/directory/books/
--- end shameless plug ---
Old 03-09-2002, 09:27 AM
Jimboat's Avatar
Jimboat Jimboat is offline
Rep: 113 Posts: 189
Powerboat design
This site might be of interest to you...for high performance powerboat design information, check out the Secrets of Tunnel Boat Design book and the "Tunnel Boat Design" software at AeroMarine Research.
