Old 12-07-2004, 03:45 PM
Bern Bern is offline
Rep: 10 Posts: 15
Depth sounders
What are your thoughts, experience and opinions of mounting a depth sounder’s (fish finder’s) transducer on the inside of an aluminum hull?(0.125 inch) Do some types work better than others? Is there a difference in styles, frequencies, are some built for it and others not, etc. etc.---Thank You
Old 12-07-2004, 07:16 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
Any fishfinder should work fine through an aluminum hull. You just have to be sure to make good solid contact between the transducer face and the hull. If it's a flat surface, pressing the transducer into a bit of silicone will work. If it's curved, scuff the surface and make a flat with epoxy first.
Tom Lathrop
Chrysler 26 Swing Keel Sailboats 13 12-10-2010 12:58 PM
Bristol 26', depth sounder going bad ridgemd Sailboats 0 08-09-2005 03:45 PM
Ideal depth of prop/ surface peircing props Sonnie00 Powerboats 2 08-01-2004 08:01 PM
calculating psi at depth jstepp590 Boat Design 13 08-01-2004 07:44 PM
Bilge Depth cklanac Sailboats 10 06-28-2004 05:32 PM
