| delta pads Does any one have experience or comments on delta pads. This is where on a deep v hull, the hull is flattened in a triangular shape going forward from the transom. This is supposed to create additional lift. I was wondering how this effects the seakeeping in larger seas. |
| interesting! am looking at waterjet intakes having similar arangements. was so dumb to lose my PB issue with delta areas for planing boats etc. i keep myself posted here and hope good info may follow |
| thanks for the reply. As a point of clarification, the boat that I am considering to have built would be 27'-30' loa, have maybe a 22 degree deadrise and be constructed of aluminium. I am planning on powering with a volvo D4 or D6 i/o duoprop. |
| Planing pads are not the easiest things to design on paper and work on a custom designed boat. I really think buying a blank hull and deck would giveyou all the benifits and no failure. Then you can fill the insides to your hearts content. |
| delta pads | halihunter | Boat Design | 1 | 06-13-2005 09:55 PM |
| Delta Pad Bottoms | Specmar.Aus | Powerboats | 4 | 10-12-2004 08:59 AM |
| Delta Pad Bottoms | Specmar.Aus | Powerboats | 0 | 09-24-2004 06:32 AM |
| prop pocket or delta section? | kapnD | Boat Design | 3 | 09-21-2003 06:39 PM |
| Bp delta Kq Kt propeller chart | nico | Powerboats | 2 | 05-10-2003 09:19 AM |
