#31
| Nope. If the heel is caused by a permanent shift in transverse balance, you are probably right. If the heel had a dynamic cause like I surmised, it is much more likely to set up the oscillation like the OP has. It's called "yaw instability" and is fairly common in some boats even if the cause is not well understood by many. A highly warped hull bottom will do this at high speed also, but for a somewhat different reason.
#32
| When a slow turn at low speed is initiated by a slight off-center position of the drive (due to slack in steering components), the turning radius is gradually reduced, due to position of lateral center of pressure. At a specific angular velocity, the boat speed held constant, the rear of the boat is "sliding outwards", causing an increased side force on the "rudder area" of the drive leg. This forces the servo-valve to a position, where it reacts by sending the drive leg in the opposite direction. With the right combination of wire play, valve deadband and longitudinal centers of mass and lateral area you have all that is needed to create a steady oscillation, driven by the hydraulics. Change one of the factors, and the resonance is broken; this is the basis for my suggestion above, and the reason for your observations with passengers at different placements ("Been there, done it all, got the T-shirt....."). |
#33
| Don't know if this makes a difference, but the more the boat is propped for speed, the bigger the effect. Power props for towing and underpowered boats oscillate much less |
#34
| There's a good article on this "wander" in the Feb. edition of Boating Magazine. http://www.boatingmag.com/find/wander |
#35
| Does the engine idle smoothly? My gut reaction would be an imbalance between the trim tab on the leg, and the prop torque at idle. Engine idle increases slightly, prop torque drives boat to starboard, engine idles back down and trim tab drives boat back to port. Perhaps a tug-of-war between the trim tab and the engine's loop-back computer controlled idle speed...? |
#36
#37
__________________ David Cockey |
#38
#39
| Tom has suggested the cause might be a coupling between heeling and yawing which sounds plausible. Has anyone with a boat with this characteristic noticed any periodic heeling associated with the yawing? Does the boat continue the periodic yawing if heeled due to passengers or other weight on one side? How does the natural period for small heel oscillations compare to the period of the yawing?
#40
| OP couldn't be bothered clarifying the matter. |
#41
![]() The center of presssure for long-slender bodies in a fluid flow does a rather dramatic bit of 'traveling' fore and aft as a fucntion of angle-of-attack of the body in question. We typically focus on how the movement of the CP affects the vertical-plane 'lift-moment' balance of a craft at high speed. But...that same characterstic is also affecting the long slender body of a 'not planing' deep-V hull in the lateral plane too. |
#42
However, this would not explain any similar phenomena with contra-rotating dual engines, unless one engine was predominant. |
#43
| I did not abandon all of you. www.wanderfin Does make a greater vertical area plate that stops the wandering instantly. It just works. Will have one put on first thing this spring. The plate does not affect anything else at any speed. Thanks for all the thoughtfull reasons. |
| Sail Forces...need help. | alimert | Sailboats | 1 | 04-09-2008 07:19 AM |
| Forces on the mast | ArZillO | Sailboats | 0 | 10-28-2004 10:33 AM |
| Aero-hydrodynamic forces | dawor | Sailboats | 1 | 02-17-2004 06:36 PM |
| Sail Forces...again | nemo | Sailboats | 5 | 02-15-2004 08:42 PM |
| sail forces, how to calculate | Guest | Sailboats | 0 | 01-04-2004 12:36 PM |
