| went for deep cycle light and regular starters, guy at the store mentioned low amp for starting again. merc startmotors need between 60 and 90 A on the dash is a parralel starter switch (using both battery's right?) looking at their site i see delphi 105 AH gives 690 A max start current have books somewere but can anyone here briefly brush up my Amp Hour black out ![]() |
| I am setting my houseboat up with 3 batteries. 1 will be for cranking the motor and the generator while the reamining two will be used as house batteries (they will be deep cycle). I am also dedicating a solar panel to each house battery as well as a smaller solar panel to the cranking battery. Over the years I have learned that you can be too prepared, especially for extended days on the water...... |
| Deep cycles will work for starting. They're getting real popular for cars that have big mega-sized stereo systems, and many of my friends use them in place of their regular batteries with no premature failures that I'm aware of. http://store.summitracing.com/egnsea...115+4294889586 The difference in amps isn't all that much, either - the red-top size 34 automotive battery has 800 cold cranking amps, while the yellow-top deep cycle size 34 has 750 CCA's, as does the marine deep cycle version.
__________________ Stonebreaker Ph.D in Redneck Engineering - Piling it higher and Deeper. |
http://www.trojan-battery.com/Products/Marine.aspx |
| Small deep water... | Sean Herron | Boat Design | 2 | 04-12-2005 01:58 AM |
| Modified Deep V | jfblouin | Boat Design | 4 | 02-14-2005 04:38 PM |
| Very deep V with strakes or progressive V | jfblouin | Boat Design | 13 | 02-09-2005 02:17 PM |
| cg on racing deep vee | John Finch | Boat Design | 2 | 10-27-2002 08:46 PM |
| catamaran vs. Deep V | Armand Salese | Powerboats | 3 | 03-12-2002 07:29 AM |
