| Decking Choice? I could just glass everything but I thought FRP would reduce the labor issue to 'joining' only. I was looking for decking choices and found FRP (slip resistant) in load bearing capacity. Application will be pontoon decking with a watertight cabin area. There is also an 1/8" FRP laminated to 1/4" luan I was considering for a roof material. I am trying to achieve minimal exterior maintenance. Painting seems so 'passe'( ) with all the tech products that are available?Pro's / Cons???????? |
| Weight is an issue, as are cost and flexibility. 1/4" stuff over a reasonable substrate might be interesting, but price it out against sheathing some plywood and see where you stand. |
They don't have a boat ![]() Daniel |
| There are two materials that may work for you. One is the material for truck sides and doors. It is plywood with fiberglass veneer. A lighter material is the foam core, aluminum faced panels made for decking on houses. It is rated structural and has a non-skid surface.
__________________ Gonzo |
1/2" FRP or 3/4" ply w/glass for decking is a toss up weight wise. Cost is double. I'm thinking it's worth that for longevity and durability in the base to the whole vessel? Plus, my deck is integrated into the pontoon, not sitting above it. By "flexibility" do you mean it should have some flex or not have flex? |
| Help Boost American Rep Points! I approve this Message Another Excellnt deck material is to go to Homy Depot/Sams clunb and get the interlocking rubber foam antifatigue mats and just contact cement them down on your PT Plywwod. It looks great and are Comfortable an your beer bottle wont break when you drop it. ( Trust me, You Will Drop it). Also absorbs impact from many other sources and keeps the deck tempature moderated. You can lay some indoor outdoor plastic grass right over it in your colour preferance of Traditional Green or Trailer Park Blue. Also all the potato chips, Blood, fish guts, Beer, Ban Du Sole' & Margarettis wash right off at ghe end of a hard day using nothing more than a garden hose and some Joy dish detergant. Its Cheap and Stylish and Durable. ![]() |
| We use a fair amount of that stuff building boat harbors. Typically this brand: http://www.fibergrate.com/frp-products/fiberplate.aspx It's nearly indestructible against foot traffic, and remains effective when wet, icy or covered in snow. However, I'm not sure that you can glue to it. Typically, it is mechanically fastened (SS bolts) to a timber or steel backing. I also don't think you can seal up the seams between the panels, so you will have gaps for water to enter every 4 feet or so. Call the manufacturer rep, and ask them if it can be glued. This stuff isn't cheap, and reps work on commision, so they are always willing to help.
__________________ One who furrows the sea enters into a union with happiness - the world belongs to him, and he reaps without sowing, for the sea is a field of hope. |
Info I've found: You can resin the joints. Using a spline helps. You can lap to it with any resin system. Attachment is unlimited. Use of resin for adhesion to wood recommended. Has a good "pull out" for screws. Span capacities aren't bad, even when using the .5". |
| Compared to other materials it's heavy, costly and has other issues. Given it's physical properties, I wouldn't use it in structural applications, unless it was static, which a boat isn't. On the other hand the thin overlays offer by some other manufactures could be glued to a reliable substrate, but again at considerable cost. |
I have found a UV resistant rubber laminate to avoid painting. Thanks for the idea direction MatthewDS. |
| Right choice? | Qsone | Education | 1 | 09-25-2008 08:45 AM |
| the right choice | sailnhawaii | Motorsailers | 3 | 10-13-2006 10:17 PM |
| Non slip decking | daedong | Materials | 20 | 09-21-2006 02:25 AM |
| Hinged Decking | Poida | Powerboats | 2 | 05-08-2006 05:05 AM |
| choice of finish/ choice of lumber | Wood Butcher | Wooden Boat Building and Restoration | 2 | 01-09-2005 02:22 AM |
