Old 10-16-2007, 08:26 AM
juiceclark juiceclark is offline
Previous Member
Rep: 71 Posts: 373
Debating Stringer Construction
The ol' time boatbuilders say just use glass over high quality plywood and build it right. You'll never have a problem if glassed correctly.
Young punks like myself often shy away from wood. A large U-shaped stringer, carbon fiber reinforced and filled with closed-cell foam sounds pretty good to me. In a 46' sportfish with a 17.5' beam, the cross stringers are very important as well as a few elbows.
How would you do it?
http://www.boatdesign.net/gallery/sh...5/limit/recent
Old 10-25-2007, 11:48 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
I don't think it is necessary by any means to have carbon fibre in stringers. But someone will correct me if I'm wrong.
Old 10-26-2007, 04:51 AM
SAE140
Having spent many weeks picking out rotten one-time solid hardwood from encapsulated stringers, I'd say "never EVER use wood". Plywood would be even worse. All it takes is a small pin-hole to allow moisture in, which can never get out - and you've got BIG trouble a few years down the line. Stringers invite people to bolt deck fittings to 'em, and if the fittings or sealant works loose ....
For short stringers supporting a deck (say) or similar, I'd be inclined to lay down some old rot-proof trawl rope, simply as a means of filling the space, then glass over that. The rope won't add much strength of course (unless you soak it in epoxy first), so ignore it when deciding how much roving to lay down to form the stringer.
Colin
Old 10-26-2007, 02:16 PM
chandler chandler is offline
Rep: 16 Posts: 378
"The ol time boatbuilders" wouldn't think of using glass or epoxy. Try oak cedar and caulk
Old 10-27-2007, 04:59 AM
Rep: 756 Posts: 3,328
Most folks build the stringers to be strong enough by their shape alone , the core, foam , cardboard , ply is ONLY to get the stringer built.
Engine beds are different tho.
FF
Stringer repair ?'s scarabfreak Fiberglass and Composite Boat Building 16 02-21-2007 11:00 PM
Help With Rotted Stringer jason58492 Boat Design 14 11-07-2006 11:16 PM
stringer building help codebluefishing Boat Design 1 09-11-2006 01:10 PM
Stringer bucket Fiberglass and Composite Boat Building 2 10-15-2004 02:21 AM
Stringer attachment johnsonmtz Fiberglass and Composite Boat Building 1 07-15-2004 12:53 PM
