Old 10-23-2003, 01:21 PM
Dwight Dwight is offline
Rep: 10 Posts: 6
ddc hull
I was wondering if someone can tell me if the ddc hull was originally designed to be used with a surface drive? Thanks Dwight
Old 10-24-2003, 07:29 PM
Rep: 10 Posts: 6
Where should I post this to get input? I may have put in the wrong section? thanks Dwight
Old 10-24-2003, 08:04 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Dwight,
You have the right spot, but I can't help you. Things slow down here at the end of the week. I'm sure someone will give you some help.
Gary
Old 10-24-2003, 08:34 PM
Rep: 10 Posts: 6
Thanks I will wait and see what people have to say.
Old 10-27-2003, 07:25 PM
Senior Dreamer
Maybe I was wrong 71 views and no help. Some more information or a picture might help. I found this,
http://www.rumrunnersyachts.com/design.htm
Gary
Old 10-27-2003, 09:52 PM
Rep: 10 Posts: 6
I appreciate your help and I am surprised that no one has replied.Dwight
Old 10-28-2003, 12:30 AM
Senior Dreamer
Dwight,
Is it just the Duo Delta Conic hull that you are wondering about? Or is it stepped hulls in general. It may surprise you that stepped hulls have been around since 1872. That’s not a typo, 1872, a long time before modern surface drives. If you want to read a first class article about stepped hulls get the October/November issue of Professional Boatbuilder, #85. The way I understand it there should be no reason for a ddc step to be limited to surface drives. But my understanding has been corrected many times in the past.
Gary
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
