| Daggerboard construction I have just bought a GRP dinghy with a steel daggerboard which is very heavy. Could I replace it with a marine ply version without any problems? |
| Unlikely. Your steel plate centerboard is likely quite thin... and the boat will have a narrow centerboard slot to match. Marine ply thin enough to fit won't have the necessary strength. Replacing the centerboard trunk to allow a thicker centerboard is probably more of a job than you want to get into. Marine ply is also not the best material for centerboards - much of the grain is in the wrong direction. Better to laminate a blank from wood strips with the correct grain orientation, then shape it. Phil |
| Thanks Phil That was very helpful and could have saved a lot of time! ![]() |
| Gybing Daggerboard? | Konstantin | Boat Design | 29 | 01-03-2005 03:07 PM |
| Daggerboard | bevan | Boat Design | 3 | 03-06-2004 08:04 PM |
| Daggerboard design | bevan | Boat Design | 0 | 02-15-2004 04:27 PM |
| daggerboard construction | Guest | Boatbuilding | 0 | 12-31-2003 10:44 AM |
| Help!!!! ( daggerboard construction or daggerboard design ) | 01639770993 | Boat Design | 1 | 12-29-2003 12:56 PM |
