Old 10-23-2009, 02:45 PM
MikeC MikeC is offline
Rep: 10 Posts: 4
Cruising Catamaran
I am working on a design for a power catamaran that is intended for use mostly in shallow protected coastal waters with an occasional fair weather trip to the Keys or Bahamas.
It is LWL 30', Beam 11'-10", draft 1'-5" (full load) twin long shaft, 115hp 4 cycle outboards. Take a look at attached photo of scale model.
I am striving for max fuel efficiency at cruise around 16 knots. The current plan is for sawn frames at 32" o/c, 2x6 keelson, 2x4 bottom ribs and 2x3 side ribs with two layers of 1/4" ply, epoxied together with fiberglass exterior.
Can anyone out there help me or direct me to information to be sure this is adequate? I have tried Gerr, but results seem ridiculous, but I may be applying formulae incorrectly. Also not too sure about roll stability, and pitch causing prop cavitation in weather.
Old 10-23-2009, 03:09 PM
Rep: 10 Posts: 4
Photo didn't attach. I think operator malfunction occurred.
Modular Cruising Catamaran ImaginaryNumber Multihulls 181 12-02-2010 02:36 AM
Cruising Catamaran with Center Board gonewalkabout Boat Design 11 10-01-2007 05:50 AM
Cruising Catamaran MrYagci Boat Design 2 04-25-2005 08:22 AM
Square boat cruising catamaran Ozark john Boat Design 5 03-04-2004 08:44 AM
cruising catamaran keel design emcmia Boat Design 2 02-28-2004 05:52 PM
