| cruise ship/ocean liner hull Hi. Im designing a hull of a small cruise ship and it's designed to look like an early 20th century british liner. Although its highly unlikely, I hope i can get it built sometime in the future. I'm using freeShip! plus Have a look at it and tell me what you think!!!! I also included the linesplan and design hydrostatics if anyone is interestedEdit: Added modified linesplan and better picture of original linesplan Last edited by pancho_es_cool : 11-12-2011 at 11:59 AM. Reason: Added new linesplan |
| Did you search trough books about ships of the era? They should contain lines plans to start from and and to compare anew design to, for sure. As to hull presented, S-shaped frames forward are not at all typical for the early 29th century ships, as I know.
__________________ All the stresses in my designs are 95% of permissible. |
| Sadly I dont have access to many books about ships of the era. The only book i have access to is "Titanic: The ship magnificent" On the internet I found the bodyplan view for the RMS Lusitania and the whole linesplan for the SS United States. I tried to make the hull look as similar to these lines plans, but not identical. They are fairly similar. But I'm not a Marine Engineer nor a Naval Architect, so I could be doing something wrong. |
| I did some changes to my hull to eliminate those s-shaped frames and all I can say is that I like it better than my original design. Thanks for pointing that fact out! I added the new lines plan if you want to check it out.... |
| What legth of vessel ? |
| I'd say the fashion right now is sail/auxiliary steamer cruise ship. Think about a replica of what ships were like before they lost ALL the sails. |
| The length is 542.5 ft or 165.354 meters. Neither too big or too small. Sail boats with auxiliary steam propulsion are neat. I'm thinking of starting a small sail/auxiliary steamer cruise ship line and then, if everything goes well, I might build this ship. |
| You mean build a scale model right? You can't seriously think that you could design a working 150m ship based on visual cues picked from one book. Ever designed a dinghy? |
| No scale model. Full size, working ship it is. I am fully aware that one can not design a 150m ship using cues from one book. It takes a lot of resources, knowledge and experience. This is a long term project which will evolve as time goes on. This is not the final version of the hull, I can assure. |
| Pacific Sun Cruise liner in very heavy seas. Internal CCTV footage. | bearflag | Open Discussion: All Things Boats & Boating | 5 | 09-07-2010 04:08 PM |
| Space on a cruise liner | monrosm@shrewsb | Projects & Proposals | 1 | 09-13-2007 09:33 AM |
| Fiberglass Hull Liner Question | Seadog | Fiberglass and Composite Boat Building | 7 | 08-14-2005 06:42 PM |
| Cruise Ship Stability | Willallison | Stability | 10 | 02-09-2005 02:09 PM |
| Cruise Ship Project | cruiserbrain | Boat Design | 0 | 03-26-2004 07:16 PM |
