Old 01-23-2010, 11:38 AM
Delaney Delaney is offline
Rep: 27 Posts: 16
Crouch formula C factor # for flat bottom hulls
What would be a reasonable C factor for something like a 19 or 21 foot flat bottom hull like a Carolina skiff. I was maybe guessing 200 to be conservative. It also seems like hp effects the C because of the great increase in hp to gain little speed. Does a lower hp that moves a hull 25 mph have a higher c than a 50 that moves it 34? Using engine test data and back calculating it sure seems to and makes sense since you have to triple hp to double speed. Thanks for the help.
Old 01-23-2010, 11:56 AM
Yellowjacket Yellowjacket is offline
Rep: 292 Posts: 249
Crouch's formula non-dimensionalizes power to weight ratio, and while it includes many other factors it is relatively accurate in that speed of a planning hull is a function of power squared. So changing the power doesn't change the coefficient, for a given coefficient the speed change will be equal to the square root of change in power. Only when you start to go very fast does Crouch (and Savitsky for that matter) break down, so the concept is valid. According to Crouch's formula you have to have 4x the power to double the speed, which is correct.
Since Crouch's coefficient also includes a lot of other things, such as drag of the shafting system, CG location, aerodynamic drag ect., it is dangerous to assume that you will have the same results by just estimating a coefficient. It is better used to predict a change in speed for a change in power. Now, if you have a coefficient from a very similar hull then you can get in the ball park using Crouch's formula. Better to use a Savitsky calculator and put in more information such as CG location and other stuff. That will get you closer to what you are trying to predict.
Old 01-23-2010, 12:11 PM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,035
Coefficient in Crouch formula depends on length also... For 20' boat with normal deadrise I to take it 160...170.
Old 01-23-2010, 01:32 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
200 seems to be a little optimistic for a general purpose skiff. I would think that Alik's number of 160 might be ok. If your boat is perfectly set up, light weight for its use and optimally designed, you can shoot for a higher constant. No matter, the correct number will be known when you run the boat
Tom Lathrop
Old 01-24-2010, 08:09 AM
Rep: 1493 Posts: 7,447
Since you are talking of a production boat, it is easy to figure out. Clear the C factor in the formula and plug in all the other data which is known.
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
flat bottom hulls Neal283 Boat Design 81 01-26-2010 02:29 AM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
Looking For Flat Bottom Molds? REDLINEMARINE Boat Molds 10 08-03-2009 02:01 PM
Crouch Formula - Repower / Depower Sea Ray 32? techyjeff Powerboats 9 12-18-2007 06:22 AM
