Old 04-03-2010, 08:08 PM
stonedpirate stonedpirate is offline
Rep: 21 Posts: 315
Cross an ocean in a dinghy?
Hello,
As some of you know, i am still obsessed with ocean crossings in a small boat.
I read "Alone Across the Atlantic" by Gerry Spiess who crossed the atlantic in a homemade, ply 10' boat.
Anyway, I have made heaps of stitch and glue designs for hulls and it got me thinking if it wouldnt be better to just buy a hull.
Serge testa did a circumnavigation in a 12' aluminium yacht and it looked similar to the average runabout dinghy.
Would converting a typical aluminium dinghy to a cabin with a sail and ballasted keel produce a boat that i'm after?
Are these hulls made weaker for inshore work? Or would the withstand a fair beating?
What kind of dinghies should i be looking at if any?
Does metal thickness and support structures etc make a huge difference when it comes to aliminium?
Thanks for any advice
Old 04-03-2010, 09:50 PM
Paul Kotzebue's Avatar
Paul Kotzebue Paul Kotzebue is offline
Rep: 272 Posts: 244
Yes, it does.
Paul R. Kotzebue, PE
www.pkboatplans.com
Old 04-03-2010, 09:54 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I think I'd like to try a hit or two of that stuff, s.p....
Old 04-03-2010, 11:55 PM
Rep: 21 Posts: 315
I'll smuggle some over.
No one will suspect a dinghy..
Old 04-04-2010, 06:25 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,840
That hull is designed for motor boating...planing if you will. You planning on using an outboard to cross the ocean?
Old 04-04-2010, 06:29 AM
lewisboats's Avatar
Obsessed Member
Not just no but He!! NO!
A boat must be specifically designed for it's main purpose...and THAT ain't it!
If you want to share though...I'm game...seems like REALLY good stuff!!!
Old 04-04-2010, 06:36 AM
Rep: 21 Posts: 315
lol
What difference would it make as a diceplacement hull when max hull speed is only like 3 knots at that length.
And i'm sure it travels quite nicely at 3knots with the outboard attached.
This thing went around the world:
Makes my dinghy look like a luxury cruiser
Old 04-04-2010, 07:53 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Actually that Australis looks like a proper little yacht,at least much more so than any of the other Stunt type boat ive seen. I think John Wellsford in NZ has a design for a boat that might suit your purpose,also Jim Betts in the US.
Steve.
Old 04-04-2010, 08:00 AM
Rep: 21 Posts: 315
Thanks Steve.
Believe it or not i actually contacted both of them recently.
Jim Betts said he no longer sells plans for his small yacht because liability insurance is too steep. And Johns boat its 2 feet to big to set the record.
10 feet max.
I wish i was a welder. Or a naval architect
Old 04-04-2010, 08:09 AM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
You will need the finest radio in the world and double the total weight in flotation. Where are you going to keep 100 gallons of water??
Old 04-04-2010, 08:47 AM
Rep: 21 Posts: 315
Radio? For boredom?
I was going to use fresh water for ballast.
Not 100 gallons though.
200 liters.
Old 04-04-2010, 04:39 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 569
You are clearly incurable, however in terms of ocean crossings in dingies, many enthusiasts would recommend the Wayfarer dingy for trips across the north sea etc.. http://www.wayfarer.org.uk/
Also the Wanderer http://www.wanderer.org.uk/
Past that look at the dingy cruising club website http://www.dca.uk.com/links.htm
I like the Baycruiser and Searaider from Swallow Boats http://www.swallowboats.co.uk/
however I see no merit in slipping down to pygmie sized vessels to cross large oceans.
Old 04-04-2010, 06:00 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
I think you should just get on with it and show the rest of us pessimistic malcontents and fussbudgets how an adventurer gets things done. The rest of us just don't have the cajones required for the job.
One place to start would be to contact some of the like minded souls that were contemplating participating in the "Round in 10" race last year. Several 10' LOA circumnavigating boats were designed and some were either built or started construction. You could probably pick up one of these cheap. In the end they decided that they were not crazy enough to pull it off. You may be better better qualified in that most demanding and crucial characteristic for such an undertaking than they.
Tom Lathrop
Old 04-04-2010, 06:08 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
As you use your fresh water ballast, which has less mass than saline, what will you use to replace it?
Hoyt
Old 04-04-2010, 07:14 PM
Rep: 21 Posts: 315
I understand the critisism. But people said the same about 40 footers and 30 footers not long ago when pleasure cruising started up.
In those days they said only ships can cross safely.
Ships sink, 30 footers sink and so do 10 footers.
Alot of people see no merit risking your life in a yacht race that whole crews die in each year, or risking it sailing to the caribbean.
Its not about size. Sailing is risky, if you dont want to die, stay home.
Norman Cross Trimaran Jerry_Lincoln Multihulls 47 08-03-2011 05:19 PM
Cross trimarans zigzag Multihulls 20 02-09-2010 09:11 PM
50 ft Cross Trimaran Susie Boat Design 1 10-26-2009 10:22 PM
Cross Curves in Freeship lewisboats Software 1 10-13-2009 11:16 PM
Cross trimaran sarge9444@yahoo Multihulls 5 09-07-2009 12:09 PM
