Old 01-09-2008, 07:23 AM
Asenyge Asenyge is offline
Rep: 10 Posts: 6
Creating hull, deck, superstructure, bowtruster etc., in Rhino...?
Hi,
I am a bit new to Rhino, so if anyone here can help me, regarding how to create the deck, superstructure, bowtruster etc., for an excisting hull already designed in Rhino, it will be greatly appreciated!
Thanks!
Old 01-09-2008, 11:13 AM
L.DOSSO L.DOSSO is offline
Rep: 9 Posts: 71
hi,
If it is a sailboat hull in which the superstructure (cabin roof) is rather small, the main part of the superstucture for your boat will be deck.
In this case you have to give deck camber so that water exit more easily the deck.
Only with Rhino, this deck,with a camber in it, won't be easy to do, but you can try, see my dwgs !
Good luck !
Lucas
Creating hull, deck, superstructure, bowtruster etc., in Rhino...?-tmp49.jpg  Creating hull, deck, superstructure, bowtruster etc., in Rhino...?-tmp52.jpg
Old 01-09-2008, 12:28 PM
Rep: 10 Posts: 6
Thanks for your drawings!
I was more looking for help/tutorials for creating the deck, superstructure, bowtruster etc., for yachts, and vessels. I have tried to create it myself, simply by trying and trying and then try again - learning new things all the time - but isn't there any tutorial available out there...?
Old 01-10-2008, 07:48 AM
orisj orisj is offline
orisj
I use Rhino for boat design a lot. Here's some tricks (sorry no real tutorial):
For hull use command: "create surface from network of curves", the curves being a couple of section lines (as few as possible), keel line, sheer line and transom line that you've created to start with (this takes some time to get it right). Begin with only one side of the hull, after completing use "mirror" command. For deck I use the "sweep 2 rails" command a lot. Other much used commands: "extrude closed planar curve", and " duplicate edge". Very useful command: "project curve to surface" (for just about any line you need projected on your hull.
good luck!
Rhino tutorial for superstructure of ship pavel915 Software 7 12-29-2006 12:38 AM
superstructure by rhino. pavel915 Software 3 12-12-2006 11:14 AM
Creating frames using Rhino or other software CET Software 16 12-09-2005 02:03 AM
+65 ft Hull and Superstructure JD Yachts Fiberglass and Composite Boat Building 2 05-07-2004 03:11 PM
+65ft Hull and Superstructure JD Yachts Boat Design 0 03-19-2004 01:31 AM
