Old 07-08-2005, 12:09 PM
Franklin Franklin is offline
Registered
Rep: 10 Posts: 52
Could a boat go 300 mph with conventional propulsion?
Top Fuel drag hydros have run over 240 mph
Could a boat go 300 mph using props or water jets?
Old 07-08-2005, 01:33 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
I have seen a modified hydroplane in the Guinnes book that I seem to recall was unofficially clocked at around 350 one way. It was some Aussie....
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 07-09-2005, 09:08 AM
Registered
Rep: 10 Posts: 52
Aussie
www.kenwarby.com
That wasn't a "modified" hydroplane.
That was a scratch-built purpose-designed boat built to break the World Water Speed Record using a turbojet engine.
Old 07-09-2005, 10:43 AM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
That could be done, theoretically.
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Old 07-09-2005, 07:03 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
In think flying will be more comfortable at those speeds.......
May the wind blow briskly in your sails!
Old 07-16-2005, 06:41 PM
Daniel Charles Daniel Charles is offline
Rep: 10 Posts: 10
It is definitely possible to go above 300 miles per hour of the water. It has been done, on october 8, 1978, when Ken Warby reached 317,6mph onboard his jet powered Spirit of Australia. This record still stands, I believe
Old 07-16-2005, 06:46 PM
Rep: 10 Posts: 857
Hmm. On flat water with a few outboards, you couuld certainly reach 200, maybe 300.
Signed-
mackid068
_________
Old 07-17-2005, 09:51 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Coulda, woulda, shouda. Aparrently they have a long way to go on the toughest part (the last 95 mph) to make 300 mph. Sam
http://www.russwicks.com/records.htm
Old 07-18-2005, 10:09 AM
Registered
Rep: 10 Posts: 52
Engines
Unlimited hydroplanes are not "unlimited." For example, one could build a similar hull (by the way, Miss Budweiser now holds the record at 220 mph) but with TWO turbines (as many tractor pullers do).
Old 07-18-2005, 10:10 AM
Registered
Rep: 10 Posts: 52
300 mph
Of course it's possible. The question was could you do it with some form of water based conventional propulsion instead of a turbojet?
Old 07-18-2005, 03:57 PM
Rep: 10 Posts: 857
I would think so, if you had ENOUGH of the propulsion systems and enough horsepower. Take a few waterjets and splice them together, but seriously, enough waterjets with a big gasoline engine should do fine on flat freshwater.
Signed-
mackid068
_________
Old 07-18-2005, 06:01 PM
That's sort of like the supposed "World Series". I was just trying to bring the topic back on track, which was about PROPELLER or JET DRIVE driven things. Do Miss Bud and competitors use props? Aside from that, I remember going to 2 unlimited races, Detroit in the early 60's and San Diego in the mid 70's when the boats still used surplus WWII B52 engines. I think they were straight 12's or V12's with short individual exhaust pipes that looked to be 8" diameter. Helen Keller would have known one of those was coming, it shook your insides. To go back to the question, to ask COULD a boat do it is sort of pointless, seeing as how all the money, talent, time and lives expended on the quest so far have only gotten to 205-220 mph. If all it took was more horsepower and more money, then someone COULDA done it, and I think they WOULDA done it, and if they didn't, they SHOULDA done it and saved everyone else all the time, trouble, money and lives it will take to actully do it. Once it's done I suppose the question will be can a boat go 400 mph ? Sam
Old 07-18-2005, 06:15 PM
Rep: 10 Posts: 857
B-52 engines? WWII, no, not connected. But, sure, you CERTAINLY could use a jet drive or propeller. Certainly could! 400 mph? I guess so, if the boat planed fast enough, had powerful enough powerplants, good propellors/impellers, lowest weight possible (remote control, perhaps?). Basically, it'd have to be a piece of carbon fiber with a few (read: 5+) outboards or jet drives.
Signed-
mackid068
_________
Old 07-19-2005, 02:16 PM
Registered
Rep: 10 Posts: 52
Speed
Top Fuel drag hydros have hit over 240 mph, still accelerating. For one thing, they have a lot more horsepower than Unlimited hydroplanes. For another thing, they're narrower and much lighter.
Old 07-19-2005, 02:19 PM
Registered
Rep: 10 Posts: 52
Propulsion
The question to ask is do props or jet drives have an upper speed limit where no matter how much horsepower you stuff into the boat they simply can't move enough water to make the boat go any faster?
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
Auto engine marinization DIY Marinizing 231 07-01-2010 07:34 PM
World's fastest flat's boat Powerboats 5 01-22-2006 11:17 AM
world records kicka$$ Open Discussion: All Things Boats & Boating 13 12-20-2002 04:51 AM
geometry of sailing Sailboats 8 10-12-2002 10:58 AM
