Old 06-06-2009, 01:51 AM
mbhanoo mbhanoo is offline
Rep: 10 Posts: 13
Cost
Can any body please tell what would be the approximate design cost of a 15m, 2T BP harbour tug with 2x225 hp twin screw conventional propulsion. Owner doesn't need any class approval.
Old 06-06-2009, 02:38 AM
Stumble Stumble is offline
Rep: 599 Posts: 1,085
Why are you designing a new boat when there are a ton of boats already in use that fits these design specs, not to mention a large number of used boats for sale that would fit these paramaters?
Old 06-06-2009, 06:25 AM
apex1
The bollard pull seems to be a bit low? Yeah and why a new design? The market is full with inexpensive vessels.
http://commercial.apolloduck.com/dis...tml?aid=109979
like this.
Regards
Richard
Old 06-07-2009, 12:18 AM
Rep: 3125 Posts: 9,397
Depending on the designer and the client/builder requirements, the cost of plans may run from a low of around 3% to as much as 7% of the vessel's completed value. Most work on a "time and materials" basis now, so call around and see what you can get in a depressed market.
I know of several stock designs in that size, which will range from 5K to 10K, depending on level of complexity.
weight vs. cost rapscallion Fiberglass and Composite Boat Building 2 03-12-2007 02:49 PM
Cost of a Wally? Willallison Powerboats 2 11-23-2005 08:51 PM
Where and how much does it cost building there? andreasmehlin Boatbuilding 8 09-21-2005 01:51 AM
production cost svenakej Fiberglass and Composite Boat Building 1 06-03-2004 02:20 PM
Cost of new deck alienzdive Wooden Boat Building and Restoration 3 03-04-2004 01:24 AM
