Old 08-21-2008, 03:26 AM
Steboe Steboe is offline
Rep: 10 Posts: 5
Corrugated bottom
What effect on the planing performance does the corrugated bottom on small aluminium boats have.
Regards
Old 08-21-2008, 05:47 AM
Rep: 756 Posts: 3,328
The trade off is extra stiffness for more wetted surface .
So the boat might be slower at Disp speeds and slower to get on plane for same fuel use.
FF
Old 08-21-2008, 12:04 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Regards
It helps to keep the hull from spinning out in turns. Without them, a smooth flat bottom will spin out and then either keep spinning or a chine will catch abruptly, stopping the spin and then usually throwing people out of the boat or into a pile in the boat.
It can be exciting.
Old 08-22-2008, 06:28 PM
Rep: 10 Posts: 5
Thanks for your input,I'm thinking it would create a lot of tubulence.
Regards
Old 08-22-2008, 08:57 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
I guess we dont want to confuse turbulence with drag.
There is no reason why a smooth corrugated bottom should induce any more turbulence than any other shape in a controlled flow, but there will be increased drag due to the larger wetted area.
Now, if you are thinking turbulence would be increased in a seaway where wave and boat action send water in uncontrolled directions unde the hull - that makes sense to me.
Old 10-26-2008, 09:54 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Fred, Sam and rwatson all have valid points.
If you could build a smooth-bottom small aluminum boat, it may have a bit less drag than the ones you actually see, complete with ridges and strakes. But it'd flop around like a sheet of cardboard, and would be hard to turn at speed without spinning out.
The boundary layer under virtually any planing boat is fully turbulent, and so is very sensitive to surface roughness. Small increases in surface roughness (texture, not strakes!) translate to relatively large increases in drag. (Hence why, when you touch the bottom of a raceboat on its trailer, it is mirror smooth.) But at 15 knots with maybe three square metres in the water, the added drag of the corrugations, rivets, etc. is really not that huge.
Old 10-27-2008, 09:23 PM
blackdaisies blackdaisies is offline
Rep: 10 Posts: 142
Just like keels do, they may make a road or rut for the boat to travel in, making it use less fuel to move it for motored boats. Have you seen the huge bulbous keels that are so long, they come before the bow of the boat does creating a trail for the boat to travel in so making easier for the back of the boat to be pulled. Does that make sense to you? If it doesn't I'll try to find urls for it.
I don't know what else other than strength it might be for if this doesn't apply.
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
through bottom repower Puzzled Wooden Boat Building and Restoration 3 11-19-2006 04:09 AM
boat bottom splitshot Wooden Boat Building and Restoration 27 11-17-2005 01:37 AM
bottom paint rharris8 Materials 6 08-10-2005 05:26 PM
Bottom Finishing Corpus Skipper Wooden Boat Building and Restoration 0 08-25-2004 09:02 PM
