Old 07-05-2006, 05:08 PM
grp.boat grp.boat is offline
Rep: 10 Posts: 46
convex vee
i have seen a rib with a gentle convex vee. apart from being stronger, what other benefit would it be? it runs out to a deep vee at the bow.
Old 07-05-2006, 05:34 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
In general, most boats built out of 'plate' - be it aluminium, plywood or whatever, have convex sections in the bow. It is primarily a function of the material being used. When you bend a flat sheet around to fit the bow shape, it naturally forms a convex section.
You are correct though - convex sections are also stronger and have been shown to provide slightly lower resistance figures too. They tend to have more buoyancy in the bow sections so are less prone to digging in and bow steering too
Will
Imaginocean Yacht Design
www.imaginocean.net
Inverted Vee Mast? HomeyD5 Sailboats 5 05-17-2006 08:18 AM
Needed Vee Jay Plans Mel Pama Fiberglass and Composite Boat Building 0 10-19-2005 12:45 AM
I/O or vee drives? snapper340 Boatbuilding 17 05-29-2005 10:20 AM
25 Vee and 41 Cat Molds maxthunder Boat Molds 5 12-15-2004 10:19 PM
cg on racing deep vee John Finch Boat Design 2 10-27-2002 07:46 PM
