| converting a rib to a rbb. hello, i have been offered a ribeye 2.9m rib but it has a leak under one of the tube seams, i was going to take it off and repair it but i thought about filling the tubes with foam, as i would like to keep it in a tidal river with flotsam and jetsom in it. so i thought converting it to a rbb as it would make it less punture proof, by branches and stuff. has anyone had any experience in doing this or can anyone offer any advice please. thanks. |
| The problem with this is that expanding foams are not designed to be continually wet or the degrade. Since the inside of a leaking tube will almost always retain water while it may work for a year or so I would expect that before long the boat will turn into a crushed foam mess. I guess if you just want a year or two out of it then it couldn't hurt, but if you want it to last it is a no-go.
| Converting to a bowrider | Bearded Clam | Powerboats | 6 | 03-04-2005 07:08 PM |
| Commments wanted on a RBB hull shape | jfblouin | Boat Design | 8 | 02-09-2005 03:31 PM |
| converting I/O to V-drive | captainstogie | Powerboats | 3 | 08-09-2004 11:39 AM |
| converting i/o to outboard | captainstogie | Powerboats | 8 | 08-09-2004 12:05 AM |
| Converting .bmp | Corpus Skipper | Software | 6 | 01-03-2004 12:37 AM |
