Old 08-12-2009, 08:20 AM
Lourencosampaio Lourencosampaio is offline
Rep: 10 Posts: 6
construction of aluminium and carbon masts
Hello all,
I am doing an investigation on: 'Development of materials in masts of racing triangular-rigged sailboats and how it has affected performance.'
I am looking for info about the construction of aluminium and carbon masts, and its advantages and disadvantages.
could anyone help me please?
LS
Old 08-13-2009, 09:22 AM
Rep: 756 Posts: 3,328
On most boats weight aloft is reduced as much as can be done. Aluminum is better (lighter and less maintanance) than wood.
Downside is it rings like a bell if struck with a halyard.So the boat next to you may keep you awake at night.
Carbon is lighter than wood , or aluminum but VERY costly , and does not seem to have the longevity of either.
FF
Old 08-13-2009, 10:24 AM
Rep: 10 Posts: 6
thank FF, but that info I already have, i was looking for something more technic, such as fabrication methods, etc etc
thanks
LS
Old 08-13-2009, 11:28 AM
Luckless Luckless is offline
Rep: 105 Posts: 163
FF
If the ringing is an issue, couldn't you fill most of the void with an ultra-low density high expansion foam to reduce it?
Old 08-13-2009, 05:31 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1925 Posts: 3,024
you need to define what you mean by performance then....since you say you interested in the fabrication. So how does the fabrication relate to the performance, ie what context, performance of what???
Since your one line is not sufficient for anyone to help you narrow down your questions/answer.
Old 08-13-2009, 07:14 PM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
FF
An old wive's tale, told by old wives?
Old 08-14-2009, 04:17 PM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
I agree with Paul B--longevity is a function of good quality design and manufacture. The better of both, the longer it will last.
As mentioned on another posting of this same topic by the same requester, see my website for a discussion of free-standing carbon fiber masts:
http://www.sponbergyachtdesign.com/StateoftheArt.htm
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
Old 08-16-2009, 04:51 AM
Rep: 10 Posts: 6
ad hoc, basically I am doing an essay on how the materials have affected performance. in that essay i must explain the fabrication methods involved in building a mast of each material, the part on performance is for me to do; i'm just asking for info about the fabrication methods.
LS
Old 08-16-2009, 05:29 AM
Naval Architect
LS
Ok...i understand, but that is still a bit vague with your definition of performance...how a material affects performance, the definition of this term still eludes me, hence not clear what it is your asking. Since already noted above by Eric, longevity and quality are mere just two that can fall into your category. So, it may be clear to you, but not to me.
The fabrication methods, well, that is another subject in itself too...
I think you're trying to cover too many subjects to answer a single question which has many different answers depending upon the 'slant' you want...
construction of aluminium and carbon masts Lourencosampaio Materials 4 08-16-2009 08:54 AM
Stepping Carbon Masts edgarm Boat Design 2 05-09-2009 02:24 PM
Carbon masts and lightning Richard Woods Multihulls 24 04-28-2009 06:11 PM
Best aluminium alloy for the masts deucalion Materials 35 02-08-2009 01:33 PM
Carbon Fibre Masts Wynand N Boat Design 64 05-05-2008 12:26 AM
