  #436
Old 11-02-2009, 08:59 PM
hoytedow hoytedow is offline
beached
Rep: 115 Posts: 320
At least black is the right color for a funereal urn for burial at sea.
  #437
Old 11-02-2009, 09:01 PM
WestVanHan WestVanHan is offline
Rep: 82 Posts: 60
Well if he claims it was poured monolithically,I'd be curious if the pour was properly vibrated and how he did it.
A slip form on that is impossible.
Maybe he had a rotating form,and did it over a day or two but thats not good enough.
And I somehow doubt it was vibrated.
  #438
Old 11-02-2009, 09:20 PM
beached
Rep: 115 Posts: 320
I wonder how many voids would show up on xray?
  #439
Old 11-02-2009, 11:20 PM
Rep: 280 Posts: 738
It would be quite cheap to do an X-ray analysis; I know people right here locally that do both X-ray and ultrasonic NDT. I had them do my carbon mast that I built in the shop to look for big voids and de-lams (passed )
I think the way you get this guy to 'put up or shut up' is to demand an X-ray or ultrasound (the NDT guys can tell you which is best) work-up on the completed hull. It's so very cheap to get this done, probably in the range of $1000-$2000 USD(for the X-ray), that I would think that ANYONE involved in this project (including Mr Wellmer) would demand such testing be accomplished. Sensibly, it should have been undetaken the day after the thing was poured/cast/otherwise 'layed up' to prevent the potential waste of doing further work toward completion of a hull that was already doomed by a built-in fault.
Of course, Mr Wellmer must have thought of this already and has such test results on hand that he is not revealing, right?
Jimbo
  #440
Old 11-03-2009, 01:22 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
What do you think?
If YOU would have to transport something from, say south America to north America, stealthy.
Would it make sense to do that in a sort of "diving, motorized container" with upwards looking windows? One could see patrol vessels at the surface.
I know, that is a dumb question, but those are the only ones suitable here.
Richard
Fortior est qui se quam qui fortissima vincit Moenia.
  #441
Old 11-03-2009, 06:23 PM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 365 Posts: 465
Originally Posted by MikeJohns View Post
Knut
I see you did a little FEA, it would be interesting to add the aft bulkhead and then have a look where your maximum stresses occur. Be nice to know E of the material too otherwise strain will be out.
If we'd assume that the aft bulkhead is supposed to hold against surrounding pressure? I'd not even consider that one, If I understand you correctly; A circular internal wall subjected to pressure? That'll pop inside the hull like a champagne cork, a bit difficult to ignore too...
I don't have the E module of concrete loaded in, used cast iron, very little flexibility in that material too, brittle in a way that makes that material difficult to use in pressure vessels. (Do we have a sort of similarity here?).
I'll remind you all I said the study (post 349, page 25) was worth close to notthing, but still there was compression stress in the window "corners" (can a circular window have a corner? Eh well... ) was in the area of 80 MPa, that was 30 bar (300 m)
No safety factor of any kind at all! In that "study";
(How many "no's" is it possible to put into one line?)
Concrete properties uncertain, 80 MPa compression stength is not average off the shelf... normally I'd assume that approx 20 MPa, is valid suggestion, reduce by a factor of 4,5 to 6, minimum. If I use my "study" as a guidance then; max dept should be:
20/ 6 = 3,3 MPa Allowable (compression around the windows).
80/300 = 0,27 MPa/m
I.E:3,3/0,27 = 12,4 m allowable depth...
Double that depth, you have a FOS of 3, that'll make this a nogo when it involves the possibility for injuries (ok I'm a conservative socialist commie...).
74,2 m (12,4 x 6) is Bravo Yankee Echo....
Guess Bntii is closest so far?
When seeing the reinforcement, aft there, at the rudders, its not too much?, I visualize a slap of concreate break off in 45° shape inwards.... I've been wrong before.... I'd love to see the actual design drawings...Please...?
And Apex, I'll not place any bet on this. I'll buy you one if we cross paths, though.. Guess we'd have something to talk about....
And if I were in the USCG, seeing a suspicious thing... lying on the seabed, i'd pop a (tiny) grenade, just to see what is is (was).... (ok now I'm a conservative evil socialist commie...).
KnutS
"it's dark and we're wearing sunglasses"
  #442
Old 11-03-2009, 06:30 PM
Rep: 494 Posts: 3,843
I'll get my Dick Tracy X-ray glasses and go there to do a survey.
  #443
Old 11-03-2009, 06:33 PM
Knut Sand's Avatar
Rep: 365 Posts: 465
Originally Posted by Submarine Tom View Post
I believe somewhere on this forum, he claimed it was all one pour.
Collapse depth numbers people for the destructive test...?.................
bntii: 85 m
watson: 0 m
s-tom: 312m
bntii: 85 m
watson: 0 m
s-tom: 312m
KnutS: 74 m
hmm, Watson is more conservative than me?
Apex? pick a number...
About the chosen colour; Black? I'd go for yellow...
KnutS
Last edited by Knut Sand : 11-03-2009 at 06:34 PM. Reason: About the chosen colour; Black? I'd go for yellow...
  #444
Old 11-03-2009, 07:45 PM
beached
Rep: 115 Posts: 320
northward bound
Originally Posted by apex1 View Post
What do you think?
Richard
Mr. W. Ellmer has found an excellent way to drown drug smugglers.
  #445
Old 11-04-2009, 12:13 AM
Mariner
Rep: 127 Posts: 341
Apex, surprisingly, is down for 1200 m!
Perhaps it's a typo and he meant 1.200 m
Tom
  #446
Old 11-04-2009, 12:16 AM
Mariner
Rep: 127 Posts: 341
bntii: 85 m
watson: 0 m
s-tom: 312 m
KnutS: 74 m
Apex: 1200 m
Starting to get spicey isn't it...!
  #447
Old 11-04-2009, 03:36 AM
Knut Sand's Avatar
Rep: 365 Posts: 465
Tom
or in fact exactly 1200 ......... (mm)?
KnutS
  #448
Old 11-04-2009, 06:18 AM
apex1's Avatar
Steamer
Tom
Of course I meant 1.200 meter (in Europe thats one thousand two hundred) but in the context only!
In a real test it will fail at about 10 - 30 meter already, at the trough hulls.
The whole coffin at maybe 50 - 70 meters.
  #449
Old 11-04-2009, 07:08 PM
dskira's Avatar
dskira dskira is online now
Pine Tar
Rep: 309 Posts: 273
Wellmer, when you leave a negative, sign it a least, don't be a coward.
Daniel
  #450
Old 11-05-2009, 04:40 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 292 Posts: 1,220
Originally Posted by dskira View Post
Wellmer, when you live a negative, sign it a least, don't be a coward.
Daniel
Ummm - you will need to translate that - what are you trying to say ????
Concrete Canoe! (Help) Luciano Boat Design 13 06-13-2009 05:44 PM
Concrete bilge corrosion RCardozo Metal Boat Building 3 04-09-2007 09:27 PM
Ballast- concrete beam Ari Wooden Boat Building and Restoration 12 02-20-2007 08:37 PM
Barge Out of Concrete? Hotel Lima Boat Design 21 12-12-2006 03:27 PM
Design of a concrete canoe fmechini Software 1 02-21-2002 12:52 PM
