| Compton Semiplaning 1986 method - Typo in the article? I am trying to use the paper from Roger H. Compton 'Resistance of a Systematic Series of Semiplaning Transom-Stern Hulls' from Marine Technology Oct. 1986 (and also enclosed on SNAME small-craft CD-ROM). I know, this is corresponding to old fashion hull lines... Based on model test results, a regression formula is given to compute residuary resistance coefficient Cr in function of Froude number Fn for both round bilge and hard-chine hulls. An example is given in the article with vessel characteristics and the corresponding EHP from model test and difference with regression computation - showing good agreement - unfortunately, no detail of the computation is given. Unfortunately, when using the regression method, I find Cr coefficients which are quiet different from what they should be. I double-checked the maths manually, and my application of the method is correct. I am now wondering if the regression coefficients given in the article are correct. Does anybody have any experience with this ? The example model particulars are: LOA 108.0ft LPP 101.2ft Ref draft 6.0ft BWL 21.4ft L/B 4.719 Disp. 163.2LT LCG 4.47ft aft of amidship WSA 2377ft2 LWL 101.7ft From these particulars, I computed the following parameters needed by the regression formula: LPP/BX 4.729 (I supposed that BX=BWL) DLR 157.46 LCG/LPP .4558 Round Bilge My results are: Fn = { .1 .15 .2 .25 .3 .35 .4 .45 .5 .55 .6 } CR = { .01324346406 .0130523335 .01355796833 .01564463618 .01876070302 .02054304344 .02177314384 .02635984895 .02779758948 .02411864564 .01987043872 } Can somebody knowing the method check my results? Do you have any correction that should be applied that I am not aware of? Best regards Vincent |
| Hi Vincent Did you find the typo? I have the same problem… LCG/LPP = 0.4558 ????? I’m using LCG/LPP = 0.044, then later multiply it with 100 in the regression equation. Apart form this we doing the same thing… And I can’t Implement the method in the same way as Compton in Fig.36 and Table 3. Any Ideas, Anyone…? /Anders |
| Americas cup yacht designs 1851-1986 | Tranth | Boat Design | 2 | 09-04-2011 12:08 PM |
| Short article about using rhino | CGN | Software | 0 | 08-19-2005 10:07 AM |
| Help with One-Off Method | LBS | Fiberglass and Composite Boat Building | 6 | 02-11-2005 10:12 AM |
| Article of H.M. Barkla | wbouwmans | Sailboats | 0 | 02-11-2005 07:49 AM |
| Article on converting 43-footer to diesel-electric propulsion | lockhughes | Open Discussion: All Things Boats & Boating | 13 | 09-01-2004 07:14 PM |
