Old 05-17-2011, 01:39 AM
starich starich is offline
Rep: 10 Posts: 7
Comparation between Watertight door & Weathertight door
Pls give me some compare between W.T door & Weathertight door. If can, update some drawing attachment.
Old 05-17-2011, 03:04 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,052
Depends what rule you are using and the size and usage of the vessel. For yachts ISO 12216 is the most relevant. There's requirements of watertightness tests and loads..
Old 05-17-2011, 11:57 PM
Rep: 3125 Posts: 9,397
Weather tight doors just keep out the rain, water tight doors withstand considerably more.
Old 05-18-2011, 12:30 AM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
a w/t door much be when shut an integral part of the structure and be able to hold back water pressure from both sides(see submarine) It can be closed by a wheel that operates all dogs at once or all dog handles can be separate and individually shut
Doors on modern ships are shut by remote means and are alarmed and s o on
Weather tight should be able to stand a stream from a high volume hose
Bugger all yachts pass the test, but they should
Old 05-18-2011, 03:21 AM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,035
Watertight and weathertight are terms used in commercial craft rules. They are likely to correspond to watertightness of category 1 and category 3 from ISO1216 respecively.
Old 05-18-2011, 09:57 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
There is no comparison between the two. They are completely different in use and function. One keeps the weather out, the other keeps the ocean out.
-Tom
mooring door help need pulsar Boat Design 2 10-05-2010 11:21 AM
transom door help bubtheboater Boat Design 2 11-12-2007 10:27 AM
Transom door..... firepiper Fiberglass and Composite Boat Building 0 03-12-2007 07:02 AM
Transom door firepiper Fiberglass and Composite Boat Building 3 10-06-2006 08:40 AM
Fiberglass door Gregory Walter Fiberglass and Composite Boat Building 6 11-27-2005 03:32 PM
