| Comercial Fishing boat design Gentleman's I am looking for good basic design of Fishing/Trolling/Lobster catching boat for North East region of US. My neighbor catching lobsters for leaving and he talk to me about building one. Particulars: Need to be as beamy on the aft deck as possible, open transom and flat aft deck, LOA from 30' to 50', build from steel or aluminum,inboard motor, Have to be very stable in stop position and at the same time give good speed and stability. I look over some designs but most of them are for recreational cruisers and I am looking for proved work boat design. I can do detail design, lofting and NC cutting but in need of help and opinion of the guys who build and operate simmilar boat. I understand that it have to be some trades off in particulars but would like to find the design to start. Any help will be appreciated Sincerely Kyle |
| Doit, You'll find very little or nothing in the way of steel or aluminum commercial lobster boat designs for a couple of reasons....... Steel or aluminum construction in North America usually implies hard chine vee or multi-chine hull form.....lobstermen won't have anything to do with hard chine boats (they use round bottom boats almost exclusively) because they haul pots aboard over the side and the pot will get caught under the chine every time...... Probably you will have to adapt a round bottom wood or fiberglass boat to round metal construction.....and there will be weight problems with this........
| That's why they do that? I learn something new every day but this implies that they also let the pots hit and drag up the side of their boat - I couldn't imagine. Might they not just use a puller on an arm over the side? Also, do they longline the pots or are they individual? If long lining, adept driving can easily maintain an angle away from the pot line. Because of length limitation, boats here are getting wider. Not unusual to see 32' x 17' aluminum boats for Bristol Bay, A seiner might be 58' by 25'. I wonder how one of those designs would work (other than the hard chine). Fuuny though, most of the hard chine boats for fishing here are long ago overweighted and underpowered to plane and might as well be displacement. Say, if it's hard chine but deep vee, would the pot slide over it without catching too bad? |
| Catamarans have become very popular, for small scale potting, around here. |
![]() adept driving? Don't believe it....this is done in a big sea and lots of wind at times, close inshore around rocks and tangled with other pot warp......boats are often sideways, sometimes pots are in strings, sometimes individual....
| Here's the same thing (hull sheathing at the hauling station) on a West Coast halibut longliner.....the sheathing above the guard is stainless steel, below the guard is strips of gumwood....... ![]()
| Yeah, Nowadays they usually use UHMW for a side board except for a classic woodie like the Leeward. I built two out of heavy FRP laminates with black pigment in the resin. They wear very well but I, personally, would go for wood. That downeaster looks well suited - I like how the pulling station is well protected from weather. I am more accustomed to pulling pots offshore. If you are tied down to not maneuver, definately harder to keep a proper angle on the pot line. I have a feeling that these boats are also singlehanded, as well, to add another dimension. Do they need to go fast, or could one of the wider designs like out here, or a cat like the one fellow suggested, be used? I imagine the other fishers wouldn't drink coffee with the guy showing up in a plastc cat... If you don't need to pack too much, a displacement cat seems a good way to go. Tangled with other pot warp? I have one word to address that - Spyderco. |
| You are now getting it direct from the horses mouth so to say having been engaged in the north east fishery on and off since i was a kid in the very types of fishing you listed.In my case it was the south west coast of Newfoundland. First look around the area you are going to fish in, see what the other fishermen are using. Each area usually has a distinct modification of a boat developed both in New England and Nova Scotia called the NOVI. The modifications are for good reason thru trial and error relating to the prevalent local sea state.Believe me even a distance of 100 miles will show some slight modification to better cope with the conditions. Example if the area is shallow water subject to fast tides creating alot of steep seas i'll bet you find the local boats have their bows flared into a design we call the Nortumberland Straight Bow.You don't need anyone to design a boat there are many used but in excellent condition for sale in Nova Scotia alone and if you want a new one i can recommend La Blanc Boats here just south of Lunenburg as well i am sure many more builders on Maine. I do recommend you go with fiberglass for low maintenance and strength. Don't recommend glass over wood as many of these are older boats that were worn out and leaking so were patched over with glass to get a few more years lifespan. Check KIJIJI, Halifax, under heading boats, i seem to recall a few glass lobster boats as they are called locally for sale. TAD's photo shows a typical Novi, TAD, i'm impresses you are familiar with these, then why should i be surprised.Hope this helps, Geo. A yacht is not defined by the vessel but by the care and love of her owner. |
| Yes we do have a couple boats over hear that look almost square. I ask about that and been told that this boats came from Canada. Been told that they have regulation for fishing fleet according to boat length and obviously people try to squeeze maximum free deck on them. Do not know true or not. Plan to build deep V with hard chine and deal with pot hauling arrangement similar to last picture from Ted. Catamaran design is very interesting idea. Does anybody have any info on that? Pots are individual and slow speed driving ,maneuverability and stability at stop condition is of great concern due to harsh environment. Appreciate your responses. |
| Blyth and Cheetah cats are amongst those used for potting and set nets in the part of the UK that I live. |
| The NOVI does okay at displacement speeds and planing? Shouldn't be able to commercially use a foreign build in US waters by the Jones Act. I just looked for NOVI hulls and I cannot figure out what the defining feature is... |
| Grew up fishing here on the west coast, then spent 15 years in Maine, designed a few wooden lobsterboats and lobsteryachts.....the modern Maine boats are quite wide (42's are now 15' wide) and almost flat bottomed aft, with 500-1000Hp speeds over 20 knots are common, more speed equals more traps per day......as long as there are a few lobsta's in em.....
| Mark, I seem to recall, Wooden Boat magazine did a big historical article on the Novi some years ago.A Novi normally will not get upon a plane although they're quite capable of getting close to it. I'm not familiar with the Jones Act but regardless of where it is built if it passes U.S. regulations i should think it would be approved, I think thats the idea behind the free trade act, then again the all too powerful lobby groups in the U.S. even over ride the government to the great loss of the voting public so who really knows. Geo. A yacht is not defined by the vessel but by the love and care of her owner |
| There you go TAD, we have something in common, fishin da lobsta, you guys did it with several traps on one line, we ran one line per trap. Yes the Maine Lobster boat/Novi is basically the same hull and have evolved into a wide low after working deck, flat bottomed aft with that heavy duty keel, housing the shaft log and usually a prop cage. Then there's that big high bow forward to take on those steep seas along the coast. They are indeed bred for their work. Geo. |
| We have some Brunos and Sisus here - Are those it? The Jones Act was ostensibly to make sure there was always an active American shipbuilding industry and shippers didn't just go wherever it was cheapest to build. http://www.akerphiladelphia.com/section.cfm?path=1,227 |
| Looking for a classic Greek fishing boat design plans | Larry | Boat Design | 16 | 06-18-2011 07:44 AM |
| FAO fishing boat design | APA-168 | Wooden Boat Building and Restoration | 7 | 02-02-2010 05:04 AM |
| design a convenient fishing boat | seawalkerboat | Boat Design | 9 | 11-18-2009 05:31 PM |
| A design for a rowing fishing boat? | fishy1 | Boat Design | 13 | 04-08-2008 01:57 PM |
| New Fishing Boat Design | grp.boat | Boat Design | 16 | 12-25-2005 09:20 AM |
