| Collaborative Mini-Project Ok, the reason this is a "mini" project is because this is a small(ish) boat. Now, to begin, the idea I had for this project was to create a yacht tender that can also serve as, for those of us without yachts, an affordable, safe and easily trailered and stored boat for cruising around harbors/lakes/bays etc. Below are requirements. Once a few designs are posted to this thread, I'll open another thread for voting on the best few. Minimum Length: 14' (May be slightly shorter) Maximum Length: 18' (May be slightly longer) Stability: Must have a CSF = Beam/(Disp/64.2)1/3 that is less than 2 (I believe that this is a reasonable amount) Cabin: None required, but a cuddy is permissible Type of hull: Must be rigid, rigid hull inflatables are acceptable as are RIB styled fully rigid vessels, monohulls and multihulls are both permitted. Capacity: No less than 2 person capacity, weight per person 180 lbs each, children count as .5 persons and weigh 90 lbs for all project purposes Hull Material: Aluminum, steel or fiberglass (May have hypalon or neoprene inflatable tubes) Please attach line drawings, profile view and top view. The procedure is listed below: 1. Ideas and pictures are posted to this thread. 2. Another thread is created for purpose of choosing best design 3. Thread regarding best design is created. 4. People post additions/ideas on Additions/Ideas thread. 5. Additions that recieve the best response are added to original design by designer, who DOES have final say on what goes in his/her design. 6. The designer posts full plans on this site.
__________________ Signed- mackid068 _________ Sailing (n.) The art of getting wet and going nowhere slowly at great expense (it's fun though) =/\= A sailing Trekkie!=/\= Last edited by mackid068 : 04-04-2005 at 02:44 PM. Reason: Editing requirements |
| Just as a note, I'll check this thread daily for responses and designs that are posted.
__________________ Signed- mackid068 _________ Sailing (n.) The art of getting wet and going nowhere slowly at great expense (it's fun though) =/\= A sailing Trekkie!=/\= |
| parameters Seems to me you have waaay too broad a set of parameters.... |
| Ok, I'll edit them.
| edit Don't edit them because of what I said- I'm only one person and perhaps others feel differently. Unless ,of course, you've thought about it some more and reached the same conclusion.... |
| I agree with your conclusion.
| I have designed an inflatable and called it a T-Cat. Similar boats are raced in UK, South Africa, Australia. The racing web site is called www.thundercatracing.co.nz My boat is only 12ft 6inches long and 8ft wide weight 165lbs and is powered by a Yamaha 50hp short shaft out-board. Speed 50mph runs very nicely with two adults but could take a third. The out-board size is optional 15hp to 50hp The boat folds and packs up to a size of 48inches x 12inches x 63inches excluding the motor. The boat is designed with each component weighing about 40lbs so easy to assemble. Can be used for diving, fishing, skiing, tender etc. At this point in time I am in the process of testing. ![]() |
| Nice looking boat. Just wondering, would you try having a rigid hull but inflatable sponsons? Any other ideas? Feel free to post them!
| So many views......
| 18 Aluminium Runabout?
__________________ JDF '"Forward, the Light Brigade!"' -Alfred Lord Tennyson |
| Sounds nice. O' course you can submit it.
| 432 views and few replies..... :,(
| Tender14 Something like this perhaps? welded Aluminum or ply/epoxy, 400 lbs crew, 250 lbs supplies, 770 lbs all up weight 7.5" draft with 12 " of freeboard. 14' long, beam of 56" leeboard or daggerboard, sprit or lug rig for simplicity ( about 65 sq ft) Row, Sail or small (2.5 hp) motor. Steve |
| I attached a pic to the last post, where did it go? |
| I'll try a thumbnail |
| Unsinkable Yacht Project | Herry | Boat Design | 35 | 02-09-2007 02:54 AM |
| Sheridan College Project | Mr.Munchy | Boat Design | 1 | 09-22-2005 08:31 PM |
| 1956 ChrisCraft Project, your opinion please... | PeterH | Wooden Boat Building and Restoration | 13 | 03-20-2005 05:53 AM |
| Ex. Seaway Group/J&J Design/Bavaria Yachtbau Project Manager available world wide. | catweaselcat | Services & Employment | 1 | 12-06-2004 10:15 AM |
| Project managment/Design job available? Turkey and/or multihulls preferred. | catweaselcat | Services & Employment | 0 | 11-20-2004 03:06 PM |
