Old 10-28-2005, 10:22 PM
rdeputy rdeputy is offline
Rep: 10 Posts: 7
Cockpit Floor Measurements
How much angle is considered adequate for proper cockpit drainage? 2, 3 or 4-degrees of elevation?
How much higher should the cockpit floor from the waterline? My current drawing allows for 3-inches at the transom.
That's it for now...
Old 10-28-2005, 10:43 PM
Deering Deering is offline
Rep: 14 Posts: 219
Depends on how variable your trim is. If you might be bow-down at times then increase the angle. I've had that problem and eventually had to add scuppers on the forward edge of my cockpit to eliminate puddling.
Old 10-28-2005, 10:47 PM
Rep: 10 Posts: 7
I always assumed that one would design his/her floor angle based on the assumption that the boat was floating in a static position. The trim angle at running speeds should only make the floor angle increase as speed/lift increases. Did I miss something? Naturally, if your weight/balance is messed up this could cause the boat to do weird things.
Old 10-28-2005, 10:55 PM
Rep: 14 Posts: 219
You're correct. You want it to drain when at rest, and when you're runnng it won't be a problem. But static trim can change due to loading changes - full fuel tanks might change things based on location of tanks, add a bigger anchor or more chain forward, mount a dinghy on the roof, install a larger battery forward, drag more stuff aboard your boat... things have a way of "happening".
Old 11-02-2005, 04:38 AM
Robjl Robjl is offline
Rep: 10 Posts: 90
Heeled trim is your problem, also does the cockpit floor widen or narrow toward the drains? Work that out and you'll know where to position the drains. I've used 1.5 degrees on a 44' cruising yacht and it worked fine.
Old 11-02-2005, 08:45 AM
Rep: 10 Posts: 7
Thanks for the response. The cockpit floor will follow the shape of the beam, wide at the front and narrowing to the transom slightly. We've always positioned the drains in the rear deck in the corners.
Cockpit Canopies on Walkaround Willallison Powerboats 19 07-01-2010 09:10 PM
C&C 25 delaminated cockpit floor CGJ Sailboats 8 05-06-2010 09:45 AM
cockpit or pilothouse EASI54 Boat Design 17 09-05-2005 06:23 PM
COCKPIT Floor HATCH drs3317 Fiberglass and Composite Boat Building 1 04-03-2005 08:27 PM
Seif bailing cockpit? duluthboats Boat Design 2 02-19-2004 02:30 PM
