| Choosing Froude Numbers Hello. I've been reading The Principles of Yacht Design and I have a question regarding the choice of Froude numbers. Essentially, how do you choose the Froude number to which you optimise the remaining design parameters? In figure 5.18 we have the equation for the residuary (wave) resistance equation derived from Delft experiments. We then go through the various contributions to the equation and it's seen that we have to choose the speed at which the yacht shall have it's optimum performance. It is stated that normally hulls are designed for maximum performance beating upwind in a breeze. If I'm designing a 28 foot medium-to-light boat, what do I need to think about in choosing the Froude number to optimise the design for? I hope this makes sense, all help appreciated. msbealo |
| How much time you spend in different conditionsm I think that most people optoimize for max speed while thesy spend most of their time at moderate speeds :-) |
| Ok, So with a Froude number of 0.40 our boat is sailing in good wind and is sitting between it's bow and stern wave and is technically achieving it's hull speed. However if want to optimise our hull for going upwind in a light breeze we should be looking at F=0.3. Principles suggests designing for a Prismatic coefficient of 0.56 which corresponds to F=0.35. However, why not 0.34 or 0.36? I guess is depends on the designed average wind conditions, but how? Is this the real area of guess, or am I missing something? On the other hand, should a yacht be designed to go as fast as possible when the wind gets up, or should it be designed to go as fast as possible in lighter winds? Mark |
| I am no expert on this, but I think, If you design a boat for Americas Cup you know where it will be sailed and you have statistics for the conditions. Probably the same for Volvo/Whitbread and Transat and Transpac etc. For a given design you can estimate the speed for different conditions, wind, waves, and directions. You can optimize for the Cp that maximize average speed. For a pleasure boat or cruising boat it's quite different. Maybe you want to optimize for maximum speed, just for fun. Maybe you want to make a ghoster, that can sail away from all others in light conditions? Another thing, it seems like it's a known fact that a Cp on the high side will cost you less in light winds than a too low Cp will cost in strong winds. Just my thoughts |
| Msbealo, I dont have my 'Principles of Yacht Design' here at work, can you post the equation?
__________________ Tom |
See this thread...http://boatdesign.net/forums/showthread.php?t=11342
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| similar reasoning applied for presumed AC Yacht Hull.. See also the thread under http://boatdesign.net/forums/showthr...t=10539&page=9 which I posted some time ago for basic design criteria of the canoe body of an ACC yacht last edition. It's should be perhaps of some help for further understanding on the matter..... If any doubts on what has been posted please feel free to revert with quotes on this forum..... cheers yades ![]() |
| By the numbers... Help!! | qwerty | Boat Design | 11 | 10-16-2006 04:00 AM |
| carbon mast numbers | rob denney | Sailboats | 3 | 12-01-2005 12:25 AM |
| IMP 1978 no numbers , where to look ? help! | whitejohn1999 | Open Discussion: All Things Boats & Boating | 5 | 10-01-2005 06:41 AM |
| Numbers Crunched? | FAST FRED | Propulsion | 2 | 10-13-2004 06:36 PM |
| How do the numbers stack up? | Willallison | Option One | 1 | 12-14-2002 11:37 PM |
