Old 08-25-2010, 03:48 AM
ViennaYachtworx ViennaYachtworx is offline
Rep: 10 Posts: 18
choosing designer / naval architect
We would like to build a 4,5-5m electric powered boat in GRP with a classic appearance. How do we find the right designer for the job? The underwater is bit more tricky as it may seam at first glance as we would like the boat to plane with merely 2kW.
Old 08-25-2010, 04:52 AM
HJS HJS is offline
Member
Rep: 268 Posts: 127
To plane with five-meter boat with 2 kW electric is probably quite difficult.
A boat with a total weight including driver of 300 kg has a planing speed around 12 knots.
And it is impossible to achieve that with 2 kW, especially if the boat has a classic look.
I enclose a picture of a boat that I designed for a client. It has very good qualities thanks to its special bottom form adapted for small engines, electric power and rowing.
Length over all 5,5 m
Length in waterline 4,8 m
Beam over all 1,6 m
Beam in waterline 1,1 m
Displacement on datum waterline 0,33 m3
Weight 130 kg
Weight with el. engine and lithium batteries 165 kg
Weight with el. engine and lead batteries 210 kg
Range with lead batteries 25 nm at 6 knots
Range with lithium batteries 50 nm at 6 knots
Speed with 8 hp outboard engine, 1 pers. 16 knots
Speed with 3 kW electrical engine, 1 pers. 9 knots
choosing designer / naval architect-img_0036-b.jpg
www.sassdesign.net
I'm not lost, I'm just uncertain of my position.
I'm still confused, but on a higher level
Old 08-25-2010, 05:48 AM
Rep: 756 Posts: 3,328
Until the batt set gets 10X to 50X the power density of what is aviliable today, most likely any "designer" you get to take this comission seriously will be a con artist.
FF
Old 08-25-2010, 06:08 AM
Rep: 10 Posts: 18
Dear Fast Fred. The battery set for a 2kW engine for a small lake boat is in LiFe under 20kg. reducing weight further is easier by putting the driver on a diet. ;-)
By classic look we meant above the waterline.
Can a 4kW outboard be enough for a 250-300kg boat (including driver) for planing?
Thanks for all the answers!
Old 08-25-2010, 06:26 AM
HJS HJS is offline
Member
Rep: 268 Posts: 127
With 4 kW outboard of proper design (most are not) and the right propeller it CAN be done.
js
www.sassdesign.net
Old 08-25-2010, 08:23 AM
Rep: 10 Posts: 18
Dear HJS,
What do you mean by "proper design" ? - We have a Torqeedo Cruise 4R in mind - is that proper enough for the task?
Old 08-25-2010, 09:02 AM
HJS HJS is offline
Member
Rep: 268 Posts: 127
Originally Posted by ViennaYachtworx View Post
Dear HJS,
Just a sketch, there is a difference.
Also check the prop, is it suitable for 12-13 knots? I doubt.
js
choosing designer / naval architect-ny-el-utombordare.jpg
www.sassdesign.net
Old 08-25-2010, 12:35 PM
apex1
Dear HJS,
NO,
the Torqueedo will not get any boat that size on plane.
I fear you will have either to give up planing speed or el. propulsion.
Regards
Richard
Old 08-31-2010, 11:39 AM
Rep: 10 Posts: 18
Dear HJs and apex,
Took a few days to receive the numbers from the engineers but nevertheless.
The Torqeedo Cruise 4.0 R develops roughly 350N at 12,5kn. A Testboat (from Torqeedo) with a total weight of 200some kg was measured at 27km/h. An Ultra highspeed Prop is also currently in development.
They do however recommend us to stay below 250kg total weight.
Old 08-31-2010, 07:07 PM
apex1
Dear HJs and apex,
No surprise,
planing speeds are NOT to achieve at these spec.s
sorry.
Richard
Old 09-02-2010, 06:07 AM
Rep: 10 Posts: 18
Dear Richard,
I'm not a naval architect but isn't 27km/h with a boat this size impossible in displacement mode? - therefore isn't it planning?
Isn't this boat powered by 1 Torqeedo Cruise 4.0 R planning: http://www.youtube.com/watch?v=JVFnI...eature=related
Old 09-02-2010, 10:30 AM
HJS HJS is offline
Member
Rep: 268 Posts: 127
No, it is not planing. According to the second video is the boat traveling 15.9 km/h, thatīs 8.5 knots. That is probable true with a 12" x !0" prop at 1250 rpm. That is the highest rpm according to the Torqeedo website. That gives a 17 % slip.
js
www.sassdesign.net
Old 09-02-2010, 11:21 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
350 N @ 12.5 kts = 2250 W effective power.
Not enough to push a 300+ kg planing hull at that speed. Besides, since the motor absorbs 4000 W, it means that the propulsive efficiency is roughly 0.55, not really a stunning value.
With a better designed prop the overall efficency could hopefully be pushed to 0.80, which would give 3200 W effective power. In that case you would have something to start with.
Old 09-02-2010, 11:37 AM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Will a hydrofoil design work? (Just a thought, I have no idea!)
Old 09-02-2010, 11:41 AM
daiquiri's Avatar
A classic appearance is required.
Naval Architect/Yacht Designer required in Germany MarineResources Services & Employment 0 07-02-2009 08:06 AM
Naval Architect, Designer Vancouver BC RDB Services & Employment 5 12-19-2006 11:54 PM
Naval Architect looking for a position as a yacht designer burak.acar Boat Design 0 06-05-2006 03:04 PM
Naval Architect vs Boat Designer Thomas Kam Materials 10 05-10-2006 04:08 PM
Looking for inexpensive naval architect or yacht designer Albert Services & Employment 6 06-03-2003 07:56 PM
