Old 02-16-2004, 12:45 PM
spank spank is offline
Rep: 10 Posts: 51
Chine Flat Construction Questions
Hi,
I am designing a plywood kit boat at the moment, and I have run into a problem trying to come up with a simple way of constructing a chine flat. My preference is to do this without using a chine-log because the aim here is to have the boat be buildable by people with limited boatbuilding skills (although to be honest, one would need a fair amount of woodworking skill and commitment to finish the project...it's 26' deep V fishing boat). The other consideration is that I want as many parts as possible to be cnc cut to furthur simplify things. Obviously the more solid wood I can avoid i.e. chine logs, the better. Any help here is greatly appreciated. Even if I do need to resort to a chine log, your insight will be helpful. Thanks in advance.
-Eli
Old 02-16-2004, 03:35 PM
Tom Lathrop Tom Lathrop is offline
Registered
Rep: 10 Posts: 72
The easy way to build in a chine flat is to let the side panel overlap the bottom panel and extend to the desired depth. The chine flat is then added to cap the area from the extended side panel to the bottom. Since you don't want a chine log, I assume you are intending to go with stitch & glue construction?
This is the construction I use which has proven easy and very strong. If you send me your e-mail address, I will send a sketch.
Tom Lathrop
Naval Architects Dubai chrisalex Services & Employment 25 03-28-2007 08:36 PM
Some Newby Questions Silenti Sailboats 18 07-10-2005 09:12 AM
new construction questions I just have to ask about fiberglass layers. donjames Fiberglass and Composite Boat Building 4 08-19-2004 04:32 PM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
Dix Radius Chine Designs bjl_sailor Boat Design 11 06-15-2004 09:26 AM
