  #31
Old 08-17-2011, 05:44 PM
Rep: 1729 Posts: 2,459
Originally Posted by Wayne Grabow View Post
Considering the drag associated with chines parallel to the waterplane versus sweeping upward toward the sheer; if the hull experiences pitch, such as in waves, the parallel chine may have greater drag due to vertical motion of plunging into then withdrawing from the water surface........
Design for least drag at the chosen operational speed. You'll find that studies on chines don't support what you've suggested above. For example vessels with completely flat sections forward can have an advantage over a V'd foresection because of their high pitch damping, providing the flat is deep enough not to slam.
Sweeping the chines up forward is nearly always detrimental to smooth water flow and trips the flow and produces a visible wave pattern at the chine waterplane intersect. The continuous longitudinal flow has far more effect on drag than periodic transient vertical turbulence.
Experiments have clearly shown that carefully placed chines reduce the total resistance over even round bilge forms, but the rules are that you sweep the chines with the flow field at the design speed and keep the exit waterplane intersect chine angle shallow. Sweeping the chines up forward was always detrimental.
A sailboat designer has to consider the heeled windward condition as well.
But the usual proviso is that if you are designing a heavy boat that will operate at low Froude numbers then it's not going to make much noticeable difference in a seaway whatever you do
Mike Johns.
3 chine multi-chine sailboats edik Boat Design 14 07-26-2011 12:22 PM
Help in Software development b1ck0 Software 4 03-13-2010 04:04 AM
Offshore Development, Offshore software development India anmsoft Open Discussion: All Things Boats & Boating 1 05-18-2006 02:45 AM
Square chine/round chine messabout Boat Design 6 03-15-2006 09:49 PM
VP Product Development Guest Services & Employment 0 03-18-2004 10:58 PM
