Old 01-21-2003, 11:06 AM
chine design/ developaple surfaces
After fruitless research in the net, please advise:
1. Obviosly for chine hulls with developable plates (i.e. hulls that can be built out of sheet material), cylindrical or conical plate development is required. What are the geometrical rules for the design of the chine, and how do you work out the geometrical drawing (on paper) , particularly for a conical surface/ plate.
2 Also, what amount of " stretch " i.e. non- truly -developable shape, can be accepted for plywood?
Any advice or literature ref. appreciated.
Old 01-21-2003, 04:23 PM
Rep: 1493 Posts: 7,447
If you design a hull with straight sections, it will develop into a flat surface. Plywood double bends. The amount depends on the type and thickness. Are you also considering polyconical shapes? If you do, it can be developed into triangular plate sections. A good exercise would be to study blueprints of designs for plywood or metal plating. Building models is a great way to learn to visualize the development of shapes. All you need is cardboard, an utility knife, tape and a glue gun.
Old 01-22-2003, 08:54 AM
FRANKIEFRANKIE FRANKIEFRANKIE is offline
Registered
Rep: 60 Posts: 43
Design
Why don't you go to Schoellmarine.com, to the man who had the mechanical patent on the first chines from the Delta Conic hull and the mechanical patent on strakes and who has been building hulls, plugs, molds, from sheet panel methods. He has good information.
FRANKIEFRANKIE
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Master in yacht design ambas Education 26 05-11-2006 01:47 AM
Looking for the right path to design and build ben_morel Education 44 11-24-2005 03:51 PM
Westlawn Shool of Yacht Design michal Education 9 03-07-2004 08:11 PM
