| Check out my first rib... ...it's not likely to perfect so fire away and let me know what I need to change? / Nojjan |
| I can only open the .jpg so maybe dimensions are provided in the .3dm First look is the transom is too short, most usually go at least 3/4 up the sides of the tube, some all the way to the top. Transom height is important, don't want the prop to be too deep or have the transom so high a long shaft is needed. |
| You want water drain holes in that transom as well. They should be big, the water mustn't take long to drain out.
| dont want to bust your bubble,,,,, but a picture of a boat is not the same as a real boat,all that is ,is theory,,could incorporate some air tight compartments in the tube ,,so if one blows ,ya still float ,,,,but kinda nice,longliner |
| For some design ideas, look at www.specmar.com RIB's |
| specmar,,,how graciouse of you ,longliner |
| nojjan,I didnt mean to sound like ,,,,,the way I am ,,,,,keep working and posting,longliner |
| Check Out Our New Website: | johnnyoffshore | Press Releases | 0 | 07-04-2007 08:18 AM |
| Check out this website... | Anau | Wooden Boat Building and Restoration | 3 | 12-06-2005 09:36 AM |
| Check this out | Jonny | Boatbuilding | 2 | 08-04-2004 02:40 AM |
| Check this one out! | 8knots | Powerboats | 2 | 01-19-2004 06:10 PM |
| Sanity Check | Portager | Powerboats | 7 | 07-03-2002 09:30 AM |
