Old 11-26-2008, 10:22 AM
Stumble Stumble is offline
Rep: 599 Posts: 1,084
Rick,
Do you really need it to be this seaworth or is it just an issue of getting it to where you want it to be? You may want to look at a less seaworth vessel that could be carried on a ship carrier to its final destination.
Old 11-27-2008, 12:09 AM
rickthorn rickthorn is offline
Rep: 10 Posts: 20
I would prefer to leave it in one ideal place, but with such world instability, this would be an uncertainty. Since this would be a large, very large liveaboard, I would have a large shop area inside also. If we found it necessary to relocate, I would have complete shop for either personal repairs, or as a business at any other location. I would have to build this on my own after getting a suitable design and blueprints/plans, etc. I am retired and on limited budget, but at least it would give me something to work toward in the future if I could get all planned and drawn up competently and correctly.
Thank you Stumble, appreciate your thoughts and ideas.
rick
Old 11-27-2008, 02:54 PM
Alve Alve is offline
Rep: 10 Posts: 3
Modules
If you are looking for something cheep and large, may be you should think in modules.
This will of course not be a good solution if you are planning to go out on ruff seas, but it can be a good idea if you want to transport it in parts as containers.
My solution would be as follow:
The upper part can be made out of rebuilt containers. Imagine the containers on the pontoons bellow rebuilt with a good-looking design. You might be able to buy used barracks that have inbuilt container fittings.
As base you can use two foldable pontoons as the ones here below.
Please note that I have the patent for the way the pontoons are transformed into containers, but I can deliver these pontoons. You can decide whether you like the pontoons to have there own engines or if you like to have them towed.
www.containerandboat.com
www.rivertrotter.com
Cheap steel barge builder around the world ?-ponton-20-fot-vecklas-ut.gif  Cheap steel barge builder around the world ?-ponton-med-container.gif
Old 11-28-2008, 12:37 AM
Rep: 10 Posts: 20
Clarifying Design Thoughts on Sea Barge...
I am only seeking design and plans...I am not looking for outside build unless place like Vietnam, India or other EXTREMELY CHEAP build country. I will not consider high wage areas, etc. Also I do not have extremely deep pockets and my funds will be limited, I must work this as a self build endeavor.
I was initially considering something like the following "river barge" type, but first 1) I immediately saw the beam size was nowhere near appropriate, because this beam is too narrow, etc. and second 2) it would be foolish or dangerous to say the least to consider transoceanic voyage in it.
Initial consideration...river barge, very nice but not of appropriate design (draft...much to low, beam...much too narrow, and problems if very rough seas, etc)
http://commercial.apolloduck.com/ima...=77484&image=3
I am now thinking/considering something like...
http://commercial.apolloduck.com/feature.phtml?id=70886
Thank you for the reply and idea you suggested Alve.
Old 12-02-2008, 08:42 AM
Rep: 10 Posts: 20
Considering Something Other Than Barge Now
The problem for me in considering a barge is barges are not designed to be self-righting. Now I am going to consider some other vessel, but cost is still my largest problem.
Old 12-02-2008, 03:07 PM
Rick,
Something like the Dutch Barge looks pretty interesting to me. But I would make sure to check the mooring costs for a vessel this large. While she may be cheap to buy the upkeep on her could get very expensive very quickly.
Personally I would be willing to take a vessel like this on crossings. The trick is to island hop and check the weather envelopes carefully. By doing your best to ensure that you never get caught out in bad weather you can go a long way toward minimizing the risk of not having a great open water vessel.
The trick is that since you are not on a time schedule it can take an extra few weeks to deliver the vessel without costing a shipper thousands in late fees. This is the trick behind a lot of small vessel cruisig and can be applied just as easily to what you are doing.
If you assume that a weather forcast is good for 24 hours, and that this vessel can motor at say 10kn. Then take a pair of protractors and step it across a map in 240kn intervals. If you can't get to a spot of land in this time frame then you detour to where you can. Then as you run and get new weather updates you can adjust your heading to being you to the next spot of land if 12 hours out your weather window still looks good.
I have used this for small boat deliveries (down to a 22' boat delivered 1,000 miles) all over the US and carribbean. It is slow, and can be tedious, but it is a safe way to bring a not particularly sea worthy vessel across open water. Plus you get to see a lof of small islands you never knew existed at the same time.
Old 12-02-2008, 09:26 PM
Rep: 10 Posts: 20
Barges
Thank you Stumble for your thoughts on open water crossings. I live full time in asia and will not be returning stateside. If I get the vessel I hope for, I would be looking to leave here for other islands to permanently "drop anchor". Nowadays there are too many governments that think you do not have any money (or rights), it is all "theirs". Just need to find someplace very remote to head to and hopefully my vessel could keep me comfortable and dry. If I can get a clean shower and some nice food I will be happy enough from that point on. Just need to find someplace remote enough!
Old 12-10-2008, 05:41 AM
colinstone colinstone is offline
Rep: 10 Posts: 44
80ft x 30ft - and with that spec - not much change out of $1m I reckon.
Colin Stone
www.luxe-motor-kei.co.uk
How to build a steel barge Big Builder Metal Boat Building 26 03-15-2012 12:30 PM
Looking for small steel barge plans BARGEASE Metal Boat Building 8 09-03-2009 12:08 PM
A cheap dream project wooden livaboard world cruiser oportunity... hansp77 Wooden Boat Building and Restoration 1 04-12-2007 01:43 PM
Adding depth to steel barge Big Builder Metal Boat Building 3 12-26-2005 11:27 AM
70ft+ steel , cheap plans genesis Boat Design 23 12-28-2004 06:19 AM
