Old 01-09-2007, 10:23 AM
Alfred's Avatar
Alfred Alfred is offline
Vagabound
Rep: 10 Posts: 6
Centers of actions
Hello everybody!
I bought end of 2005 Prolines 7. Now there is no longer support and I have some questions.
In Hydrostatic there are centers of actions
-Long Ctr. of float
In which connection I have to consider this point?
-Vertical CLP
-Longitudial CLP
How is the defination for this expressions?
Old 01-09-2007, 10:40 AM
PI Design's Avatar
PI Design PI Design is offline
Rep: 309 Posts: 604
The Longitudinal Centre of Flotation (LCF) is the centroid of the waterplane area, ie the 'middle' of the shape of the hull outline at the waterline. This is the point about which the hull will rotate (although it will move as the boat heels and trims).
I'm not sure what CLP stands for.
Old 01-09-2007, 11:13 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Center of Lateral Pressure sometimes also called CLR (Center of Lateral Resistance)
Wynand
A scatterling of Africa
Old 01-09-2007, 02:09 PM
PI Design's Avatar
Rep: 309 Posts: 604
That what I thought, but how can you have a vertical CLP?That would be CVP?
Old 01-09-2007, 10:24 PM
Alfred's Avatar
Vagabound
Rep: 10 Posts: 6
Thanks for the reply
To PI Design,
the following text is exactly the same as in Vacanti's Prolines 7
-Vertical CLP
-Longitudial CLP
Relating to 'Ctr of Float' I would think that this piont is a neutral value which isn't to place in a given position, in contrast to LCB and LCG which is placed in a certain relation to the design.
Old 01-10-2007, 02:47 AM
PI Design's Avatar
Rep: 309 Posts: 604
The centre of flotation is useful to know, but not something that you would pre-determine. For a static, or pseudo-static, case it is in a fixed position, usually a little aft of the LCB. It can be used for trimming calcs.
I still think vertical CLP is a nonsense, but guess it means the depth below some datum point that the combined hull/keel/rudder lift force acts at.
Old 01-13-2007, 03:36 AM
alpamis34 alpamis34 is offline
Rep: 2 Posts: 63
You can figure out the location of vCLR and L CLR by doing some tests such as towing tank or CFD. The parameters that you need are the roll moments yaw moments and the Sideforce values.If you divide the roll moment by the Side force you will obtain vertical position and with the yaw moment division you get the horizontal position.
Tumer Berk
Old 01-15-2007, 09:09 AM
Alfred's Avatar
Vagabound
Rep: 10 Posts: 6
Thanks for reply
V CLR and L CLR are certain points in Prolines 7
Wifh your replys I can use this values.
Schooner sail plan- centers of effort Scott Carter Sailboats 15 11-05-2006 02:33 PM
