Old 03-01-2007, 08:14 PM
Gene H Gene H is offline
Rep: 10 Posts: 5
Center of Gravity
I have a 36 ft trawler with twin diesels. I'm changing transmissions and the new output shaft has a two inch drop from the old transmission ouput shaft centerline. This means I have to raise the engines two inches. Does anyone know if that is a minor adjustment or a major adjustment to the boats center of gravity. Obviously the longitudinal c/g goes up verticaly on the boat. Is two inches too much for a 36 ft long, 14 ft wide 10 ton boat? I believe the engine weight is 1200 to 1400 lbs per engine.
Old 03-01-2007, 08:51 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Boat's COG will rise around 0.25"
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 03-01-2007, 08:58 PM
tri - star tri - star is offline
Rep: 3 Posts: 87
You are right to be carefull.
It WILL effect the C. of G. The wrong way. For stability....
This is one of those Sq. Root multipliers.
Consider: SUVs are only a few inches taller than a conventional
car. - And they are MUCH more prone to rolling over - than a car is.
Never mind the 4 wheel drive.
Stongly suggest - that you seek out a reg. P. Eng. that does marine
stuff. The cost will minimal. By the hour it's hardly any time a'tall.....
Especially, considering the cost of re - floating your vessel !
Cheers !
High Speed Boats. Center of Gravity mvd535 Boat Design 21 07-10-2007 12:56 AM
any software for finding the lightship weight and position of centre of gravity pavel915 Software 4 12-27-2006 04:20 AM
Rotate pulleys using gravity. Jigar111 Propulsion 18 12-02-2006 12:12 AM
Center Consoles usmarinekurt Powerboats 3 10-09-2006 04:26 PM
Longitudinal Centre of Gravity (LCG) jileateta Boat Design 2 02-02-2005 11:06 AM
