#91
[/quote]From Capt. Vimes: if we have a hull working in displacement mode only and we want to reach hull-speed - i.e. speed/length ratio = 1.34 (2.43 in metric) - we need a Cp of 0.63 to even reach hull speed... if the hull has a Cp lower than that and is not of a long and narrow persuasion - we would end up with a highest achieveable speed less than this - am i right? to fully comprehend this and understand what happens there is really giving me troubles... Cp defines the fullness of a hull - so the more the hull 'fills out' the block of water between the perpendiculars and beam at WL the faster it could go in displacement mode... could it be that with a higher Cp the ratio between wetted surface and displacement is getting lower (less wetted surface for a given displacement) and thus reducing frictional resistance enabling a 'fuller' hull to reach higher displacement speeds?[/quote] Capt. Vimes, Sorenfdk's description is correct. All boats will be able to exceed hull speed given enough power. But not everyone wants to go that fast, and you pick your Cp for your intended sailing or operating speed, which is usually less than hull speed, maybe speed-length ratio of 1.0 or 1.1. At 1.34, you can expect resistance to go up exponentially in most cases, and so really need a lot of power to exceed that speed. You are correct in that with higher Cp the ratio of volume to wetted surface is lower, but you are not reducing frictional resistance. Frictional resistance is directly proportional to surface area, and even with larger Cp, surface area increases slightly. It happens that with higher Cp, the wave-making resistance does not increase as fast, and so you can achieve a higher speed before you hit "the wall". Some years ago, a fellow naval architect that I know spent some time in a model tank testing the model of a 30' round-the-buoys racing sailboat (which his client paid for) in order to optimize the Cp to a range between 0.53 and 0.54. That was the speed that they were shooting for (between 1.0 and 1.1 speed-length ratio) and so wanted to minimize volume and wetted surface for the best all-around performance. They felt that the effort was worth it, although I did wonder at the time. The boat certainly performed well and it was nicely built. However, the success of the boat depended largely, too, on the ability of the crew. Bad crew meant mediocre performance. But when they had a rock-star crew on board, the boat did really well. Eric
#92
| thank's soren and eric... it is getting brighter... yet another corner of my dark-room you all call "boat design" illuminated... ![]() |
#93
Are you saying that they only tried to minimise skin-friction and not the total hydrodynamic resistance (i.e. wave + friction + form)? Or was wave resistance assumed to be implicitly accounted for by fixing the range of Cp? Thanks for the many insights so far, Leo. |
#94
I found the effort interesting in that this was for a 30' sailboat. The client had some money to devote to that, which is very rare for a boat that size. Also, the budget did not allow any testing on different keel designs, which on a racing sailboat, has tremendous influence, particularly in this case where the keel was very long and narrow and with a bulb at the bottom. What they were able to do, however, was derive a very good map of where the CE and the CLP travel as the boat heels (they move back and forth, the rig more so than the keel, obviously) and so had a more precise analytical way of establishing the balance between the two. The boat in the end balanced very nicely. You are right in that wave making resistance was not an important factor, really, because the design speed was well enough below hull speed that it became of secondary importance. Form and friction resistance were the particular elements to deal with, and most importantly at different heel angles, therefore different wind conditions. Eric
#95
| My first hydrodynamics contract (with E.O Tuck) was on a 1990's America's Cup yacht. The boat was by far the fastest in a straight line, straight down into the mud of San Diego harbour Quote:
Experimental resistance with small hulls (< 2.0m) is particularly uncertain. The type of boundary layer trip used to promote turbulent flow can result in variations of in residuary resistance of up to 18%. See for example, "From model scale to full size. Investigation on turbulence stimulation in resistance tests of high speed craft", Bertorello et al, FAST 2003. Thanks, Leo. |
#96
Eric
#97
There is quite a deal of scatter in the results submitted so far. If all the tank operators "know what they are doing" why are there such large differences between tanks? Experienced CFD practitioners, who also should know what they are doing, often tweak their models to agree better with experiments. Picking the right set of experiments seems a bit problematic to me. As you said, experiments and CFD should be used as aids to intuition, and not some absolute, independent, infallible measures of reality. Leo. |
#98
Now everyone--please don't steal this thread with brownie recipes! This simply makes a good metaphor. Remember, we are discussing basic naval architecture. Next week I am taking up Displacement/Length ratio which is the next step on the way to the relatively new concept, The S Number (it is actually over 20 years old, but much newer than the other design ratios). Eric
#99
| Different tank depths and widths and different trim conditions could be the cause of the scatter. Perhaps tank configuration has more effect on results than hitherto suspected.
#100
| ....just shows actually how a good designer earns his money doesn't it. Boat design is NOT just getting a design program and playing about for a few days, it is about UNDERSTANDING the principles and USING them in association with your own experiences to create what is known as a "good" design....just how many designers do you know that are capable of writing and explaining to us like Eric has been doing....he understands......that is the difference. Once again, thanks for your comments.
#101
| So much effort goes into tank testing in smooth water for small boats that will operate in a seaway. Like Erics example of refining the Cp and testing numerous variations. As soon as the vessel starts its dance on the waves a lot of that drag reduction refinement is worthless. Winged keels and pitching come to mind. Powered Ship hullforms are a lot easier to refine in the tank. I still get a thrill though watching the generated waves flow away from a hull I designed the first time the model is run, I think I intuitively get more from observing that than I do from the resistance curves. Tanks are very usefull for general comparisons but as Eric implies you need a lot of gelled knowledge and experience as to how you interpret the results. I am trying out 1.5m models, Others have used 1.2m models for refining hullforms for a variety of craft with apparent success. Optimized through computerised CFD is just a line to scare the opposition isn't it ?
#102
Leo. |
#103
There are also a host of incompletely understood issues to do with tank boundary layers on the bottom and the side-walls, and the finite records of wave elevations. Quote:
The FAST 2003 paper I cited earlier used a Telfer-like procedure with three geosims of length 1.805m, 2.347m and 4.494m. The authors' conclusion was that L < 2.0m was inadequate for model-ship correlations for Fn < 0.6. The other conclusion was that the type of turbulence stimulator had a very large effect on the results. So, how do experienced naval architects interpret the effect of that? Or do they ultimately just accept what is given to them by the tank operators because there is nothing better available? The International collaboration is using L=3.048m and L=5.72m, and the shorter hull seems barely adequate, IMO. Quote:
![]() All the best, Leo. |
#104
I'd agree that they are probably best-placed and best-informed to combine the myriad of factors entering into a good design and to make educated, experienced compromises. But they are not necessarily the best tool (and I mean that in the nicest possible way) for investigating specific design factors in great detail. At some stage they have to rely on the advice of specialists, or just accept the data that is supplied to them on trust. Cheers, Leo. |
#105
| Thats why we collect and cite papers, lifes too short to be anything but a Spork.
| Boat Flotation | virtruvian | Boat Design | 2 | 06-22-2009 11:14 AM |
| flotation | shannon | Materials | 5 | 04-27-2009 09:56 PM |
| flotation | daedong | Boat Design | 10 | 08-02-2006 04:52 AM |
| Implications of cement ballast on hull measurement | ldrumond | Metal Boat Building | 3 | 07-22-2006 03:39 AM |
| Flotation Tubes | nightz13 | Materials | 1 | 09-07-2004 04:55 AM |
