#61
In the calculation of the trim, there is a term involving Zw*Rf, where Zw is the vertical location of the centroid of wetted area, and Rf is the skin-friction. Now, Rf is clearly important, otherwise you would not be concerned with minimising wetted area to reduce it. That is indisputable. My argument is that if Zw is not small, then the moment, Zw*Rf, is also not small. I am happy to concede that in many cases Zw will indeed be small, but I want to see an actual calculation to be completely convinced. Hand-waving arguments and guesswork are not always reliable. OTOH, unnecessary calculations are a stupid waste of time ![]() There are also unusual cases (e.g. SWATH and SLICE) where Zc could be quite large, but the moment Zc*Rf is small compared to other terms in the trim and sinkage equations. All the best, Leo. |
#62
#63
| Leo Undoubtedly......doubt. Fred |
#64
| In the case where the hull is heeled so the wetted surface is asymmetric, the asymmetric drag would result from the effect of lateral flow especially across chines.
#65
| The biggest drawback of assymetric hulls is not wetted surface , but changes in centre of buoyancy when heeled , which leads to loss of directional stability. |
#66
| No Brent.. The center of buoyancy stays where the CG (and the vertical vectors of the heeling forces) make it to be.. It's the position of the hull and alignment of the wetted form compared to sail and keel/rudder alignment that changes. If that change has an effect to directional stability is another matter but not allways negative.. thou reckon you meant helm balance but that's not so simple either ![]() |
#67
| trim angle? as explained so well by eric - if a boat heels the CB, CF tends to move aft (the wider the stern the more they do so) - causing the hull to trim... what would be an 'acceptable' trim for a ship at - lets say - 30° of heel? considering the vessel is designed as an 'all arounder' and should have good compromise between down- and up-wind performance... i have no doubt that 10° would be way too excessive but i also have no clue what would be 'in range'... |
#68
In sailing yacht design, I typically check my heeled waterline at 15 degrees heel without correction for displacement and trim to see where the CF moves to momentarily--it gives me a snapshot of what will happen to trim before the hull settles into a steady state of flotation. And 15 degrees heel is a normal and comfortable heel angle. Eric
#69
| Up-coming notes: To the class, The plan for the following few weeks will go as follows:
Stay tuned! Eric
#70
| Nice thread! Danke Herr Kollege. Thanks Eric for taking the time! Regards Richard |
#71
| Hi Erich, Quote:
You stated that catamarans and trimarans (which have long narrow hulls) have very high Cp ratios. Is 0.6 in this case low, average or high ? This is where the caper resistance calculation is about as low as I get it, it is around 210N at 7 kn. Displacement is at 2000kg each hull.
#72
Fanie, I don't know what you mean by "caper resistance calculation"--that is an unfamiliar term. As you probably know, there are three major components of resistance for a boat traveling through the water: Frictional resistance, Form resistance, and wave-making resistance. At slow speeds, below hull speed (speed-length ratio V/Lwl^0.5 <= 1.34, or Froude Number V/(g*Lwl)^0.5<= 0.4) Frictional and Form resistances make up the larger part of the total. Above this limit, Wave-making resistance overshadows frictional resistance and becomes the major component--in most conventional designs. It's possible to break through that 1.34*Lwl^0.5 speed barrier if the hull is light, long, and narrow. Such hull shapes have been shown to achieve speed/length ratios greater than 2.0 without planing--that is, still in displacement mode. Such hulls have very small waving making resistance, and part and parcel to that is that they also have a Cp of about 0.70. This is a limit--generally to achieve even higher speeds, Cp does not have to go any higher--it levels off. All you need to go faster is to add more power. So, in your case, it depends on how fast your boat is intended to go. At Cp = 0.6103, your target speed is at or just below hull speed. If you want to go faster, your Cp should be larger, according to the chart I posted earlier. Eric
#73
| Hi Eric, The caper resistance is a chart in Freeship that indicates I guess how easy your boat would move and displace water, so frictional and form resistance. I doubt any one designs a hull to be slow so if you want to ask how fast the boat is intended to go, when the pirates appear it has to have unlimited speed If the fish bites it must remain right where it is ![]() I'm trying to visualise what the interaction of the water with the boat would be when the CP changes, say from 0.6 to 0.7 Does this prolong the following wave making when a certain speed is achieved so a higher speed can be achieved before wave making becomes more than the friction and resistance or does it merely improves the friction and form resistance ?
#74
| Well, how about that, I actually answered myself there ![]()
#75
| Form and friction resistance go up with the square of speed, but they stay pretty much the same proportion to each other. Wave-making resistance is inhibited with longer narrower hullforms. We see this all the time in vessel design--long narrow hullforms have lower overall resistance because of lower wave-making resistance. The flow interactions that play with changes in prismatic coefficient--the ends of the hullform are fuller, have more volume--are very difficult to visualize outside of a model tank, or outside of a full-scale side-by-side comparison of differing hullforms. Eric
| Boat Flotation | virtruvian | Boat Design | 2 | 06-22-2009 11:14 AM |
| flotation | shannon | Materials | 5 | 04-27-2009 09:56 PM |
| flotation | daedong | Boat Design | 10 | 08-02-2006 04:52 AM |
| Implications of cement ballast on hull measurement | ldrumond | Metal Boat Building | 3 | 07-22-2006 03:39 AM |
| Flotation Tubes | nightz13 | Materials | 1 | 09-07-2004 04:55 AM |
