#301
They are simplified! These formulae are based upon what, measurements (empirical), of a small range of vessels, but are treated as all encompassing. They are not and cannot be. These formulae are just “tools”, nothing more. If I wish to drive in a nail into some wood, which ‘tool’ would I use? Would I select a saw or a chisel?..no. I could drive it in, eventually, but the right tool is the hammer. But then which type of hammer, a mallet, a claw hammer, rubber (soft afced) hammer etc. Trying to treat simplified formulae as absolute, is incorrect. There are always caveats. One needs to understand what these caveats are. Are these tools useless then…no. Not at all. They are very useful indeed. But, they just provide guidance and a “ball park figure”, that is all. To assume more than this is ignorance of what said formulae represents and the end goal. |
#302
But in 'Propeller handbook' there is only one formula for displacement craft - formula A. No other tools provided.In power prediction, different tools are different prediction methods, for different purposes, conditions and types of hulls. And the purposes and conditions are to be specified. In simplified formulas in question they are not. I have seen many times how people make mistakes with prediction methods (using software) without knowledge, and more often - using simplified formulas they do not fully understand. On previous pages I referenced Westlawn student making calculations for his powerboat with Holtrop (well outside limits of method), and school publish it in their newsletter! What kind of faculty is there?? Amazing... |
#303
| One should not be given a choice. One should learn what the choices are available. Without learning what there is out there and how these are derived and hence used, one is making the same mistakes as someone using a simplified formula and treating it as an absolute. Quote:
If there is no caveat about its applicability and that the reader should research more for others that may be and provide references for them (as a start), then yes it is misleading the inexperienced designer. There are many books with just one formula. Since the author is ostensibly promoting ones own work. But those books that refer to many other ‘works’ on the same matter have much more credibility. |
#304
| Students should be given a choice and study all spectrum of tools. Professionals can find those tools themselves. Quote:
Those with single formula are not engineering books. Meanwhile preface says it is 'easy-to-use guide for... naval architects'. Have You read it? Quote:
#305
| Keith's Identity Discovered! To all readers, Thanks to intrepid observer Vincent Guilbault in France, we now know the identity of the Mr. Keith of Keith's Formula. You may recall that in the last chapter of The Design Ratios, we reviewed Crouch's Formula, Keith's Formula, and Wyman's Formula. We knew who Crouch was and who Wyman is, but Keith was an enigma--mentioned only in Skene's Elements of Yacht Design--and no other information about him or his formula was readily known. Well, thanks to Mr. Guilbault's discovery, we now know that he was Mr. H.H.W. Keith, a professor of Naval Architecture at MIT, and his formula was published in a 1912 book, "Propellers," by a fellow professor at MIT, Cecil H. Peabody. I took the liberty to update The Design Ratios with this information and am uploading the revised document here. I made a few other minor editorial changes, but basically, it is all the same. The note below was added to the bottom of page 54, so if you would like to simply copy and print the following text and add it to your current copy, you can. Otherwise, simply download this latest version (same file name) from here. This new version is also posted on my own website for free download, in the Articles Section. Eric The following text is added to page 54: NOTE: Update, January 2011: Observant reader Vincent Guilbault of La Baule, France, discovered who Keith was. H.H.W. Keith (I don’t know what names the initials stand for) was a professor of naval architecture at Massachusetts Institute of Technology (MIT). He contributed his formula for speed prediction in a book called “Propellers”, written by Cecil H. Peabody, also a professor at MIT, and published by John Wiley & Sons in London, England, in 1912. Other records discovered on the Internet reveal that H.H.W. Keith was an author and member of SNAME up until at least 1941. You can see a digital copy of “Propellers” at the following link: http://www.archive.org/stream/propellers00peabgoog#page/n0/mode/2up. Go to page 28 and you will see Keith’s Formula as he originally wrote it: Speed, V = C x ((L x P)^0.333)/B Where: V = speed in miles per hour or knots L = Length overall, feet P = Break Horsepower of engine or engines B = Extreme Beam, feet C = Coefficient that ranges between 7 and 11 for different length/beam ratios: Type of Boat Cruiser: For L/B = 3 to 5: C(mph) = 9 to 11; C(knots) = 8 to 9.5 Runabout: For L/B = 5 to 7: C(mph) = 8 to 10; C(knots) = 7 to 8.5 High Speed: ------------------: C(mph) = 8 to 9; C(knots) = 7 to 8 Notice that instead of Displacement, the original uses Beam overall. L is also within the cube root. The C coefficients are correspondingly different, so you cannot mix the two versions—be clear as to which version of this formula you use. The C coefficients are still based on experience—that is, you should know some boats that perform according to these coefficients in order to use them reliably. Special thanks for Vincent Guilbault for this discovery!
#306
| Good grief, 1912 eh ! You mean to tell me they already knew back then what we don't know today in 2011 ![]()
#307
| Thanks a lot! I have just quickly revised the document you attached, and it looks prety good. I will take the time to read trough it thoroughly! This will dramaticaly help me to completely understand hull design. ![]()
__________________ www.nikldesign.si |
#308
| Hello Eric! I saw an article in the Feb/March 2011 issue of the Proffesional Boatbuilder Magazine, regarding the S number and also about this thread. ![]() Congrats ![]()
#309
Eric
#310
| Dr. Sponberg Dear Eric, We always do what you tell us to, don't we? My best wishes to you, Carl |
#311
| Carl, I never take it for granted and understand that you have a schedule and an editorial agenda to meet. But I must say you treat me very well, and thank you for that. Eric
| Boat Flotation | virtruvian | Boat Design | 2 | 06-22-2009 10:14 AM |
| flotation | shannon | Materials | 5 | 04-27-2009 08:56 PM |
| flotation | daedong | Boat Design | 10 | 08-02-2006 03:52 AM |
| Implications of cement ballast on hull measurement | ldrumond | Metal Boat Building | 3 | 07-22-2006 02:39 AM |
| Flotation Tubes | nightz13 | Materials | 1 | 09-07-2004 03:55 AM |
