| Center of Effort Help I have looked through other posts on this issue and still can't figure it out. The books i have and from what i have seen in other posts say that you are supposed to measure back from a point (forward Lwl in my case) to the center of effort of each sail, then multiply that number by the area of the sail, repeat for all sails then divide that number by the total sail area. I have designed a cutter rig and when I do the math I am getting a huge number. has anyone else had these problems. I am using feet and inches for the length back and square feet for the area. I don't know what i'm doing wrong. Thanks Cody |
| Remember that you have to do it in both X and Y direction. ![]() For example (main + jib): Xce = (Xce,main*Amain + Xce,jib*Ajib) / (Amain + Ajib) Yce = (Yce,main*Amain + Yce,jib*Ajib) / (Amain + Ajib) My guess is that you have messed something up with the unit system. Can you show some numbers? |
| my numbers main = 179 sq ft Stay Sail = 118 sq ft Jib = 127 sq ft total area = 424 measurements back from LWL Main 15.5 ft Stay 6.5 ft jib 2.75 ft so (15.5*179)+(6.5*118)+(2.75*127)/424 that should be it, right I'm more concerned now with the horizontal ce i will find the vertical later. thanks for the help |
| Horizontal and vertical CE's are interrelated: the higher the rig, -the more forward CE of sails should be... . Could you post some sketch?
__________________ All the stresses in my designs are 95% of permissible. |
| I found the center by drawing lines from the corners to the opposite centerline on the triangle. Pretty standard way i think. |
| It is the traditional geometrical method for estimation of the CE position, but it has not been confirmed at all by CFD and wind tunnel testing. In reality, CE of sails moves with angle of attack relative to the wind. Let me quote myself from another thread (don't want to re-type everyhing ):"the center of effort (C.E.) of the sails move aft with the increase of the A.A. To give an idea of this, increasing the A.A. from 10° to 20° can shift the C.E. from the initial 30% to about 40% of the mean sail chord. It means that for a, say, 42 yacht with a sail having some 14 feet mean chord, the C.E. can travel by more than 1 ft for 10° of change in A.A." Try searching this research paper in internet: "Computational and experimental study on performance of sails of a yacht" by Jaehoon Yoo and Hyoung Tae Kim. At page 1341 it contains a numerical example showing the huge difference between traditionally calculated CE (the one you did) and the CE obtained from experimental and CFD work. Cheers |
| Rudder Center of Effort Migration with Speed | Erwan | Multihulls | 7 | 09-06-2009 08:50 PM |
| center of effort gaff sail | susho | Sailboats | 7 | 03-09-2009 02:08 PM |
| center of effort in multiple headsails | dsuursoo | Sailboats | 2 | 09-17-2008 03:31 PM |
| Underwater foils --- Center / Effort and Percent / Chord? | epoxyman | Sailboats | 19 | 12-26-2006 09:18 PM |
| center of effort of a gaff sail | EAP | Sailboats | 40 | 11-16-2006 06:46 PM |
