| Center Board Design I own a C&C 40 keel center boat. The center board needs to be replaced. It is made out cast iron and badly corroded. I am also consider a redesign using a wing keel insert in place of swing center board . Looking for input and possible place it could be built. I live in Florida. It weighs about 800 lbs. ![]() |
| It's likely the board can be reused after it's cleaned up and had a new bearing and pivot pin installed. A new board of steel wouldn't be my first choice as a replacement. I'd elect to make a board of 'glass with a lead weight. Sure you can re-engineer the stub, to be a fin, but it would be a more costly way to do things. I wouldn't recommend a wing, but a bulb may offer some possibilities, though in a shoal draft configuration not a very good choice. Contact me by email for more information. |
| Center Console Design | Thano1 | Boat Design | 13 | 02-04-2009 07:32 PM |
| Center-board | r.mike | Boat Design | 2 | 01-21-2008 07:55 PM |
| Dagger board and rudder design | peterking182 | Boat Design | 2 | 12-12-2007 02:47 AM |
| Cruising Catamaran with Center Board | gonewalkabout | Boat Design | 11 | 10-01-2007 04:50 AM |
| Center pod design needed | Titan | Boat Design | 4 | 07-29-2004 12:24 AM |
