Old 10-15-2004, 02:09 PM
CE and large roach
when calculating the CE of the sailplan would you include the roach of the mainsail? my current project has a fairly large roach and I was wondering how others deal with this type of situation.
I don't want to put the mast in the wrong place now do I !!
Sam
Old 10-15-2004, 09:34 PM
Rep: 1623 Posts: 2,343
Sam
The CoE by this method is allways a ballpark figure and you may have to allow some adjustment anyway such as varying mast rake or playing with a bowsprit length. If you are working your design from a similar vessel and she has been balanced then just copy their CoE. Otherwise look for similar vessels.
Anyway to answer your question. I always take the main as designed with full roach and the full fore triangle area.
Mike Johns.
Old 10-16-2004, 05:07 AM
Rep: 700 Posts: 3,208
Our sailboat has a Cutter rig with mast stepped 50% LWL aft of the bow.
The roach of the 1975 fully battened main extends about 2 ft BEYOND the backstay.
By using "pulltruded" FG battens we have never broken a batten.
The main is great as it takes a shape from the battens at very low wind speeds giving a nice setting sail.Also great is the ability of the sail to stand and not flap it self to death when not loaded.
Sailing out an anchor , or motorsailing in a river frequently require luffing , which the sail does with no damage.
FAST FRED
Old 10-17-2004, 12:21 AM
Rep: 2891 Posts: 8,795
Typically, no, you don't count the area in the roach.
Old 10-18-2004, 04:54 AM
Thanks for the replies.
I see we have conflicting views!!
anyone else have an opinion? the score is 1 all!!
Sam
Old 10-18-2004, 09:37 PM
Doug Lord
voodoo?
Definitely count the roach on a fully roached and/or square head type main. If you don't your calculations for many things will be in the mystical realm-or just plain wrong.
Old 10-18-2004, 09:57 PM
Chris Krumm Chris Krumm is offline
Registered
Rep: 10 Posts: 92
I presume this is in relation to finding relationship of lead of CE over CLR, so finding the corresponding "rules of thumb" for finding corresponding underwater profile area is in order too.
Check out the earlier "Center of Lateral Resistance " thread in the Sailboats forum. SailDesign mentioned in one reply he typically uses mainsail area with full roach with full rudder (+keel area + canoe body profile area); or no roach with 50% rudder (+keel + canoe body profile area).
Chris Krumm
Old 10-19-2004, 06:58 AM
Rep: 66 Posts: 640
PAR,
Not that I doubt your expertise, but I don't understand!
To find CE, you combine the projected areas of your sails. Excluding the roach means discounting it's effect. If the effect is so small you can discount it, leaves me with the question: why is it there?
Regards,
Dutch Peter
Old 10-20-2004, 04:24 PM
I use no roach and actual head sail area for CE and 50% rudder (approx. depending on rudder design) + underwater profile (body and appendage separate) for CLP.
Some folks use different values. Some the fore triangle area + main including roach (wise if much round) I've seen as little as 10% the rudder area and as much as 100% of the rudder area included in the CLP figures.
People for years have been trying to increase the angle and width of the head on mains. It makes getting the most out of the height, but in machines where the last 10% of a knot must be squeezed out of the craft to be competitive, not necessarily so in more conventional designs. I was speaking of more conventional designs, which you may not have.
If you have a big roached main, include the area in the calculations. How have you changed the rig, requiring the refiguring of your sail area?
