| Catamaran Design - estimating speed from weight, rpm and thrust Hi everyone I am new to this forum and hoping to get some help. I am in the process of designing an unmanned catamaran. The hull is almost complete and thrusters are going to be installed soon. I want to do some tests on the thrusters before their installation to calculate the thrust produced at a given rpm. This will be carried out on a stationary paltform. Suppose I have the the thrust and rpm information together with the vessel weight, is there anyway I can estimate the speed of the catamaran in the water? Are there any other parameters need to be identified? Does anyone know anything about the bollard condition? Thanks |
| You will be testing in the bollard condition, that is defined as zero speed (tied to a bollard). The thrust will generally fall off with speed. The resistance will increase depending on hull shape, weight, separation, etc. Estimating resistance accurately is not a trivial problem, and there are many approaches that you will find referred to in strings here. The speed at which thrust equals resitance, accounting for propeller / hull interaction effects, is the speed. |
| Leo Lazauskas' software called 'Michlet' could help you - see http://www.cyberiad.net/michlet.htm bye Hans |
| Monohull verses Multihull powersailers / motorsailers | brian eiland | Motorsailers | 257 | 12-14-2011 12:10 AM |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 05:00 PM |
| bigger props faster ship? | Peter H | Boatbuilding | 23 | 02-01-2010 01:08 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Propeller THRUST | WilliamS | Boat Design | 9 | 10-08-2005 06:31 AM |
